norfolknudger wrote:Ok so im looking for a 3.73 axle ideally but ive been offered a 3.58 but im wondering what the difference is between them and if it may be geared a bit high for my truck as it’s only 110hp can get it chipped I suppose plus I carry no weight in my truck only use it as a car really any help or advise appreciated
norfolknudger wrote:Hay up knobrott my mistake it’s a 115 and definitely a rwd twin wheel truck fella
norfolknudger wrote:Thanks for reply knobrot my work vans a 125hp single wheel rwd running a 3.73 rear axle and at 50mph it’s only running @1500 loaded just sounds nicer and seems smoother than my truck which i only use as a car heaviest thing she carries is my 100kg superjet once in a blue moon that’s why im wondering if i would get away with a 3.58 also what horse power I could get from my ecu without changing it ie would it go to 125hp to help push her along im not after top speed just want to reduce rpms and engine wear hope this makes sense
