Mk7 fwd euro 4 turbo replacement
Postby DanMK7uk » Sun Apr 13, 2025 8:40 pm
Hi everyone,Any tips / guidance on replacing a turbo on these.
How hard to access the 4 nuts ontop ? Looks awkward
The 3 on the cat dont look to bad aslong as they come off !
DanMK7uk
Re: Mk7 fwd euro 4 turbo replacement
Postby knobby1 » Mon Apr 14, 2025 12:35 am
DanMK7uk wrote:Hi everyone,Any tips / guidance on replacing a turbo on these.
Depends on which engine you have as to which turbo is fitted....the lower powered ones, 85, 110 & 115 use a wastegate type, the higher powered ones 130 & 140 use a VNT type.
Good luck getting the nuts off...a good soaking with loose juice a few days before may help...but if they're badly corroded...they often get rounded off or snap the studs.
Postby DanMK7uk » Mon Apr 14, 2025 6:14 pm
Cheers knobby its a 115 in question
Can the studs be replaced? Worth ordering before?
DanMK7uk
Postby knobby1 » Mon Apr 14, 2025 8:30 pm
DanMK7uk wrote:Cheers knobby its a 115 in question
115 will be a wastegate type...replacing the studs may be a good idea....but getting the old ones out can turn into a mare....if badly corroded, they usually just snap of flush.
Postby DanMK7uk » Mon Apr 14, 2025 9:10 pm
Oh dear ! Il be spraying lots of wd on them on the days leading up..
Maybe a drive first to get it all hot wouldn’t hurt to
DanMK7uk
Postby knobby1 » Mon Apr 14, 2025 10:10 pm
DanMK7uk wrote:Oh dear ! Il be spraying lots of wd on them on the days leading up..
Not a bad idea.....can't hurt at least.
Postby andz327 » Mon Apr 14, 2025 10:45 pm
DanMK7up I've got a used turbo of a low miles 2010-11 engine if your stuck
andz327
cron
