boombaxx wrote:Hi i am trying to fix a 2.2 tdci fwd 2010 transit. My problem is that it will not turn over. I have changed nothing except the electronic switch at the back of the ignition switch. As i heard that could be a problem area and it was cheap fix. Does this have to be reprogrammed?. The van opens as normal and and the ignition when turned on looks good until i turn it over then nothing. I have put it thru the computer and it says no faults. All i can hear is a clicking from the main fuse box in the engine bay. It started to be hard to get going for a while.
