Has anybody upgraded bulbs and which ones do you recommend.
Led the way to go now ? Whats available.
gt_addict wrote:Plasterer is my official title. But we do plastering, rendering, silicone render, floor screeds, occasional complete bathrooms for select clients (ones that only want us to do it) and other various bits if the clients want us to do it. Even if its not out trade we have a good knowledge base and happy to turn our hands to anything, hence the forums for advice before doing my sideline of mechanic for the family
Not seen any led that work properly with mk7 lampsDanMK7uk wrote:Has anybody upgraded bulbs and which ones do you recommend.
T350camper wrote:As I understand it, the law now prevents you from upgrading a vehicle that has halogen bulbs, to HiD gas discharge or LED (even though they may be better). You may struggle to get through an MOT, depending on the vigilance of the tester. You would need headlamp leveling and depending on the size of the headlamp itself, a cleaning system also (wipers and/or washers).
I changed the bulbs in one of my older cars some time ago and there was a real improvement. They were not higher wattage, just 50% brighter...and no risk of falling foul of the law. I can't remember the make of the bulb kit (it was just 2 bulbs in a plastic box) but they worked well...although had a shorter life.
