Results flowtest 2.0tdci 2003
Postby Stevelien » Mon Jun 02, 2025 6:10 pm
I have done 2 flowtests FIFA 2.0tdci engine vacuüm actuator:
4 minutes idle: 18-18-18-21 milliliters picture 2
Idle and different breaks with middle/high rpms: 57-51-48-60 millitres picture 1
See pics, scale measurement of the bottles is some brexit UK standard I Guess but converted to common Paris Napoleon EU standard without import duties.
Injector 4 with all Delphi components is too much deviant. I am gonna change those Delphi components into my another old injector and put this back this week for a new flow test. Maybe the electric actuator is worn out.
New rough testdrive confirmed NO Limp mode after mr. Muscle actuator arm and turbo vane system cleaning job. Sometime solutions are easy, and do not thrust on the pre canbus Ford fuel pressure fault indicators with a vacuüm actuator.
Stevelien
Re: Results flowtest 2.0tdci 2003
Postby wojciech » Thu Jun 05, 2025 10:12 am
All values ​​are already very high - the advantage is that they are even. Even this fourth injector does not differ much proportionally from the others. The fourth is already at the limit, but the other three are not far from it.
I would suggest replacing the valves in all injectors. Also replacing the nozzles.
Replacing the nozzles when the old ones have more than a hundred thousand miles on them gives a clear improvement in the engine's operation, especially when revving up. And it protects the pistons from cracking the bottom during knocking combustion.
I would not use any cheaper substitutes, only original Delphi parts.
wojciech
Postby Stevelien » Thu Jun 12, 2025 9:00 pm
wojciech wrote:All values ​​are already very high - the advantage is that they are even. Even this fourth injector does not differ much proportionally from the others. The fourth is already at the limit, but the other three are not far from it.
All components were already replaced by Delphi stuff…
Stevelien
Postby knobby1 » Thu Jun 12, 2025 10:14 pm
Stevelien wrote: All components were already replaced by Delphi stuff…
Were they old, second hand, reconditioned or new..??
Users browsing this forum: Google [Bot], Trev_
