Ash90 wrote:Hello guys to cut a long story short I’m onto about my third slave cylinder they keep failing/popping and losing fluid dripping through the bottom of the gearbox what could be causing this when it’s replaced all is fine for a couple of months then back to square one replacing and bleeding the clutch any advice will be much appreciated .
knobby1 wrote:Ash90 wrote:Hello guys to cut a long story short I’m onto about my third slave cylinder they keep failing/popping and losing fluid dripping through the bottom of the gearbox what could be causing this when it’s replaced all is fine for a couple of months then back to square one replacing and bleeding the clutch any advice will be much appreciated .
Must be the Mk6 2.4 135 with the 6 speed gearbox..?? Has the clutch/flywheel been replaced recently..??
Ash90 wrote:knobby1 wrote:It’s the mk6 2.4 115 with 5 speed box buddy it’s never been changed in my ownership of the truck it seems perfectly fine when the slave is fully functioning biting point is almost as you just lift the pedal and never been any sign of slipping at all the fella I bought the truck off did say it had just been replaced but I never take anyone’s word for it without proof I’m guessing it will of been done it’s on almost 150k
Do you think it could be over stretching because the clutch has worn but wouldn’t my biting point be really high if it was I’m at a bit of a loss trying to figure this one out I mean I don’t mind having the box out of it if I have to but it’s a last resort thing
I have a few other bits I’m doing to it whilst it’s off the road I’ve had the egr out and cleaned it all think I’ll order a blanking plate and blank it off and I have smoke on start up coming through the vents and the smell of smoke when I’m driving checked the manifold for leaks and nothing I’ll plug it in tomorrow see if anything pops up on the snap on diagnostic and go from there
knobby1 wrote:Ash90 wrote:knobby1 wrote:It’s the mk6 2.4 115 with 5 speed box buddy it’s never been changed in my ownership of the truck it seems perfectly fine when the slave is fully functioning biting point is almost as you just lift the pedal and never been any sign of slipping at all the fella I bought the truck off did say it had just been replaced but I never take anyone’s word for it without proof I’m guessing it will of been done it’s on almost 150k
Ok...a bit strange as you said you were losing fluid through the bottom of the gearbox which threw me into thinking it was a 6 speed...
With the 5 speed, is the clutch lever bent or cracked..?? There were a couple of different clutches and slaves for them I believe...depending on which flywheel and clutch was fitted...single or dual mass etc..
http://www.catcar.info/ford/?lang=en&l= ... gyMjQrMjcy
http://www.catcar.info/ford/?lang=en&l= ... NCsyNzI%3D
http://www.catcar.info/ford/?lang=en&l= ... grMA%3D%3D
scas wrote:i had the same thing a few years ago on a 115, went through 4 slaves over a year and a half. i changed the perfectly good borg and beck clutch, which id thrown in 2 years before and replaced it with a valeo and it never happened again. it was only when i had the new clutch that i realised the borg and beck clutch was idioticly heavy, which i presume was straining and eventually bursting the all plastic slave cylinder.
no need to, just pull the vacuum hose of the egr and stick a screw in the rubber hose, same thing, less work.make a blanking plate tomorrow,
