What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby Airthies » Thu May 08, 2025 10:19 pm
Got it running like a train.
Aboody Choo Choo train.
It doesn't like running on 4 cylinders
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Redvee » Fri May 09, 2025 11:10 pm
Finally got the right sized rafter for the awning at the 2nd attempt and two trips to Leominster so fitted that today.
Added the other Fuel Lagoon goodies to the van with the addition of some door organizers, just need to carpet the ply door cards.
Redvee
Postby loot » Sat May 10, 2025 1:17 pm
Sold the 2 medium high doors, 8)
07 350 170ps
Ids map here
loot
Postby Airthies » Sat May 10, 2025 9:28 pm
Did a heart transplant.
And it fired on first turn.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Redvee » Thu May 22, 2025 11:30 pm
Carpeted the ply door cards for the barn doors, TBH I didn't need the ply doorcards to back the organisers but a I'd bought them I made use of them. Made use of the Interior disassembly tools I bought from Temu to remove the under bonnet insulatin and blow the washerpipes through, the washers now hit the middle of the screen but they went higher when I tested them straight after, as long as the jets continually hit the middle of the screen I'll be happy.
Redvee
Postby Airthies » Thu May 29, 2025 10:52 pm
Redvee wrote:Carpeted the ply door cards for the barn doors, TBH I didn't need the ply doorcards to back the organisers but a I'd bought them I made use of them. Made use of the Interior disassembly tools I bought from Temu to remove the under bonnet insulatin and blow the washerpipes through, the washers now hit the middle of the screen but they went higher when I tested them straight after, as long as the jets continually hit the middle of the screen I'll be happy.
Always set them high and slightly out to the side of where you want them as once your driving the wind reduces their trajectory and you'll soak the bottom middle 3" of each screen wiper.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Redvee » Sun Jun 01, 2025 10:52 pm
Been watching the recommended wheel trims on Fleabay but they've been out of stock recently so bought from another seller who confirmed they'd fit the wheels despite eBay saying they won't, seller was right they do.
And yes they have been secured with cable ties.
Redvee
Postby ajpmsport » Fri Jun 06, 2025 4:49 pm
Had the codes read :( . Well last few weeks, repaired inner off side cills, partly the outer following mot advisory. New track rod end gaiters. New rear lights. New power stearing pump ( but still squeeling like a ****)
The vans drained me. Soon to be a classic. :(
MOT tomorrow fingers crossed
ajpmsport
Postby vansit1 » Sat Jun 07, 2025 11:29 am
cant see any of your pics, but you have to slowly bleed the servo pipes while cranking the engine for 30 seconds or use a vacc pump
vansit1
Postby loot » Sat Jun 07, 2025 12:47 pm
ajpmsport wrote:Had the codes read :( . Well last few weeks, repaired inner off side cills, partly the outer following mot advisory. New track rod end gaiters. New rear lights. New power stearing pump ( but still squeeling like a ****)
To bleed the transit pas pump make sure the fluid is topped up with the correct fluid start the engine and slowly turn the steering wheel from full lock to full lock several times.
I've found that was all that was needed. Where is the squealing coming from? Make sure the crankshaft pulley isn't splitting,make sure the serpentine belt tensioner isn't worn ,it can allow the belt to catch on the rubber bit and chirp etc.
07 350 170ps
Ids map here
loot
Postby vansit1 » Sat Jun 07, 2025 2:59 pm
manual says to turn it only while cranking, so maybe the running engine will add some bubbles sometimes
vansit1
Postby loot » Sat Jun 07, 2025 6:37 pm
vansit1 wrote:manual says to turn it only while cranking, so maybe the running engine will add some bubbles sometimes
It probably means if the pump is dry then the running engine will damage it. But when the reservoir is full and you start the engine the fluid moves around quick enough.takes literally moments to bleed. Obviously when it is low or not bled, then don't force the steering wheel as it will simulate hydraulic lock. My van starts literally on the button so I doubt I would get any turn on the wheel in between cranking it. :wink:
07 350 170ps
Ids map here
loot
Users browsing this forum: audvaldid, Lukeydookeydoo
