DPF AND CAT
DPF AND CAT
Postby Dunham1 » Fri Jun 13, 2025 6:25 pm
Does the Mk7 Ford Transit 2.4 and 2.2 engine have the same dpf and catalytic converter setup and can they be swapped over, both are Drop side, LWB and RWD
2009 plate and 2012 plate
TIA
Dunham1
Re: DPF AND CAT
Postby Dunham1 » Fri Jun 13, 2025 8:53 pm
I’m getting mixed opinions here
So it’s mk7 2.2 rwd, lwb dropside (2012)
I’ve got a split in the flexi pipe that’s goes to the cat / manifold (I believe), I was told you can’t repair or replace as it’s one piece and something about the dpf
Also I’ve been asked by a local mechanic if it’s the metal flexi pipe or the rubber flexi hose
The guy that found the split said it’s the rubber one, but I’ve also been told they don’t have rubber ones ?!
Dunham1
Re: DPF AND CAT
Postby knobby1 » Fri Jun 13, 2025 9:46 pm
Dunham1 wrote:I’m getting mixed opinions here
Are you talking about the exhaust or boost pipes, no part of any Transit exhaust has a rubber flexi pipe.
Not the same...2009 is Euro-4 and doesn't have a DPF, 2.2 RWD is Euro-5 and does have a DPF.
Flexi is part of the CAT.
Mk7 2.4 Euro-4 here:
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3D
Mk7 2.2 RWD Euro-5 here:
