Mk6 2.4tdi not charging?
Postby JRHartley » Mon Jul 07, 2025 8:56 pm
Ive put a early one wire fuel pump on this 2.4tdi, I purchased this van with a pump fault & Im not sure if the charging system was working before I changed the pump.
I know of some one doing the same pump swop & found the charge light now stays on, but he's getting a charge from the alt'.
Is there some thing Ive disturbed on the right side of the engine bay, solenoid? wiring socket etc? or is the alternator done. Is there a more basic alternator that will bolt straight on? any one have a schematics of the charging system? Thanks for any help!
JRHartley
Re: Mk6 2.4tdi not charging?
Postby DanMK7uk » Mon Jul 07, 2025 10:17 pm
What voltage are you getting engine running across battery.. ?
DanMK7uk
Postby JRHartley » Mon Jul 07, 2025 11:13 pm
12.4v at all rpm, I read its a smart alt? I wonder if I could strip it down & use regular diode pack & regulator?
JRHartley
Postby knobby1 » Mon Jul 07, 2025 11:42 pm
JRHartley wrote:12.4v at all rpm, I read its a smart alt? I wonder if I could strip it down & use regular diode pack & regulator?
Mk6 doesn't have a "smart alternator"...if engine is running, you should have ~14.4v across the battery. Is the battery itself ok..?? Have you had it properly load tested..?? Not just a voltage check.
Postby JRHartley » Tue Jul 08, 2025 12:03 am
Ive not had it load tested, would connecting a another battery via jump leads do for the test? thank you
JRHartley
Postby JRHartley » Tue Jul 08, 2025 12:07 am
Knobby, on ebay a seller has this in the description..
BRAND NEW 110AMP HEAVY DUTY ALTERNATOR COMPLETE WITH CLUTCHED TYPE BELT PULLEY
TO FIT
FORD TRANSIT MK6 2.4 TD rear wheel drive, DURATORQ ALL Di,TDE,TDCi MODELS FROM 2000-2006
INCLUDING SHORT & LONG WHEEL BASE,TIPPERS,JUMBOS ETC......
SEE OUR SEPERATE EBAY LISTINGS FOR STANDARD 75AMP UNITS
***DOES NOT FIT MK7 MODELS FROM 2006 ONWARDS (SEE OUR SEPERATE LISTINGS FOR THOSE)***
A**IMPORTANT**THIS VEHICLE USES THE FORD SMART CHARGE SYSTEM,THE VEHICLE BATTERY MUST BE FULLY CHARGED
WHEN THIS ALTERNATOR IS FITTED TO AVOID PROBLEMS OR DAMAGE TO THE ALTERNATOR.
JRHartley
Postby DanMK7uk » Tue Jul 08, 2025 12:54 am
If memories serve me correctly, on a smart charge alternator the voltage goes down under load .. i think.. perhaps opposite. Silly idea!
Dk if yours has that or not.. how many connections on the multi plug on the alternator?
Either way, if voltage aint changing atall. It dont sound happy.
On smart alternators pulling the multi plug off effectively makes them a normal type.
Check directly at alternator end on the big red cable and to ground on alternator casing.
DanMK7uk
Postby JRHartley » Tue Jul 08, 2025 1:05 am
It has one socket with two thin wires & one thick feed wire. I think Knobby is correct on this being Non smart?
JRHartley
Postby knobby1 » Tue Jul 08, 2025 1:41 am
JRHartley wrote:Ive not had it load tested, would connecting a another battery via jump leads do for the test? thank you
No...the battery has to be "loaded" using a proper battery tester.....sometimes they can show good voltage but fail miserably when loaded.
Postby DanMK7uk » Tue Jul 08, 2025 10:25 am
JRHartley wrote:It has one socket with two thin wires & one thick feed wire. I think Knobby is correct on this being Non smart?
Sounds like conventional then.
As knobby says, its the amps that count which a load test checks, however it wouldn’t stop the alternator putting out what it should..
Check with a multimeter, across b+ thats the fat red cable on the alternator and ground alternator casing, on a clean metal scratch probe on casing. That will tell you what its putting out with no doubt about anything between battery and it.
DanMK7uk
Postby JRHartley » Tue Jul 08, 2025 12:17 pm
Ill try that, thank you.
JRHartley
Postby JRHartley » Tue Jul 08, 2025 6:46 pm
Its not working, removed it and checked its really in a sorry state.
I have a Denso new Alt', it has the main out put post, and a four pin socket marked L, IG, FR, S. Ive run the part numbers but nothing comes up.
B is clear, charges the battery, goes to battery
L, lamp, exciter wire, connected to a bulb
IG, connected to Ignition switched +12V
S, sense, connected to battery to provide the actual charge voltage.
Is the above correct? thank you
JRHartley
Postby DanMK7uk » Tue Jul 08, 2025 7:19 pm
IDK on that one
If your old one has 2 cables … maybe it aint right
Pop the number over part on the alternator
DanMK7uk
Postby JRHartley » Tue Jul 08, 2025 7:24 pm
Its Denso 09-122291-AB TN102211-0700
JRHartley
Postby DanMK7uk » Tue Jul 08, 2025 8:20 pm
Comes up as aston martin lol
Is that your main mode of transport sir :mrgreen:
DanMK7uk
Users browsing this forum: DanMK7uk, Google [Bot]
