Mk6 radio replacement
Postby zipppy » Thu Sep 05, 2024 12:06 am
I want to replace the standard https://i.ebayimg.com/images/g/Ai8AAOSwkl5Xd9RL/s-l1600.webp radio with something a bit more modern. Ideally Android Auto capable etc. Can anyone suggest a good one?
zipppy
Re: Mk6 radio replacement
Postby scas » Sun Sep 08, 2024 12:33 pm
Just use any double din radio, it'll take 5 mins with a dremel to make the hole a bit bigger. Here's my 35 euro one with a reverse camera off amazon
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Postby scas » Sun Sep 08, 2024 12:44 pm
Less fuzzy
04 mk6 2.4 di 90
05 mk6 2.4 di 115
scas
Postby van_man » Fri Aug 01, 2025 1:20 am
Sorry all to bump an old thread, but it seemed better than just making a new one.
In regards to fitting a double DIN head unit into a mk6 Dash, how is it mounted? Is there a fitting kit that is used?
Currently my head unit is just jammed in place with cardboard and sometimes falls into the dash, I'd like to fix this.
Any advice would be very helpful.,
thanks
2001 Transit, MK6. 2.4L manual, RWD, Mid roof, MWB
van_man
Postby Stevelien » Fri Aug 01, 2025 8:12 am
If you adjust the gap at the top a little with a dremel tool it is possible to fit a common double DIN frame into it. I fitted a Kenwood/JVC DMX7722DABS with a short frame length of 7,5 cm. It takes more space at the top than the gap of SCAS radio. Now driving with wireless Apple Car play in Europe!
Stevelien
Postby van_man » Fri Aug 01, 2025 1:17 pm
nice install.
what does the double DIN frame attach to though?
I have the plastic facsia with a hole big enough for the headunit, but behind that fascia there is nothing to attach to? no structure. just the plastic frame of the dash.
Thats where I have the cardboard jammed in to hold the headunit in place.
van_man
Postby Stevelien » Sat Aug 02, 2025 11:57 am
Just bend the lips of the frame behind the plastic dasboard gap. I remember the frame was so tight already without bending. Good luck.
Stevelien
Postby van_man » Sun Aug 03, 2025 10:28 am
Yea, that's what I was concerned about.
Doing that hangs the cradle and weight of the headunit right on the edge of the plastic facsia. Give it some hot aussie UV sun damage and vibrations and it'll crack the whole fascia over time, they are already pretty hard to find uncracked.
It's not the first car I've seen this happen on
Guess I'll just have to make something from scratch...
Cheers anyways.
van_man
