Rear Axle Crown Wheel /Pinion Fittment
Postby JRHartley » Sat Sep 27, 2025 4:18 pm
I have a mk6 2.4di single wheel axle that is 5.13, whats the options on crown wheel & pinion swaps ? am I restricted to mk6 or would other model year Transits c items fit?
( I have replaced CWP's before) Thanks
JRHartley
Re: Rear Axle Crown Wheel /Pinion Fittment
Postby knobby1 » Sat Sep 27, 2025 9:19 pm
JRHartley wrote:I have a mk6 2.4di single wheel axle that is 5.13, whats the options on crown wheel & pinion swaps ? am I restricted to mk6 or would other model year Transits c items fit?
There's only 3 ratios available for the Mk6 "non-Dana" Transits, 4.63, 5.13 & 5.14. Some people go to the effort of fitting a Mk7 Dana...9 ratios available. Getting the disc brakes and ABS working with them can be an issue if your Mk6 has ABS.
Postby MinorMatt » Tue Sep 30, 2025 9:05 am
You arn't limited to mk6... mk2 to mk6 all fit. In addition to Knobbys list there is a 5.8, but nobody in their right mind would fit that unless they were driving up mountains towing a heavy trailer!
4.63 is the least revvy ratio you can get for your axle
Users browsing this forum: Google Adsense [Bot], Tonecamc
