Elsaetka wrote:My 2.2 TDCi has a strange misfire during warm up and I'm struggling to find the cause. My best description is, it starts first touch even in minus temperatures, under power it pulls like a train and there is no smoke or knocks, engine is perfect. When the van reaches speed for example 30 and I back off the throttle, it chugs, 'misfires' in other words under light throttle pressure. Go back yo acceleration and it's fine. I've put new injectors in it, and a fuel pressure regulator too, and it's made no difference. Also, at idle during warm up, if I dip the clutch it runs rough too. As soon as it warms up after a few mins, it's perfect across the board? I would love to hear from someone who has solved this. Thanks in advance.
Elsaetka wrote:No fault codes recorded and that's on Forscan and a new Snap On.
Elsaetka wrote:It's a Euro 4 and it had new injectors fitted, coded in and a new fuel filter 2 weeks ago, I usually do these things myself but this time circumstances stopped me from having the time. I did use a trusted colleague who is very familiar with Transits and I'm assured it was done correctly. That said, I do have Forscan plus access to the latest Snap On machine, if anything is recommended. The new injectors greatly improved it, but it's not perfect until warmed up. I did read a post when researching that said there's an upgrade, but of course that could be nonsense. Appreciate the help on here, thank you.
Elsaetka wrote:Firstly, thank you for the reply, your response has me thinking. Forget the references to an update, it was just a comment I came across when researching this fault, they probably meant a re learn anyway.
I have no idea if a re learn was done but will eat my hat if it was if I'm honest, I bet he will have just coded in the new injectors. Is there a link you can please point me to that shows how to carry out the re learn, I have Forscan and an interface I can dig out although I have rarely used it. I'm familiar with Mercedes Star and Saab Tech 2 but not so much Ford, a guide would be very useful. I will just do it myself if I can, I don't have time to go back to where it was fixed plus I prefer (and usually always do) things myself so I know it's done properly.
