I'm not a mechanic and need your knowledge...
The van has a constant black smoke. even at idle. you can easily smell the unburnt diesel
I have a 2006 Ford Transit FWD with a 2.2L Duratorq TDCI. 3 mechanics and ford stealership looked up the car and couldn't fix it. I cant afford throwing it in junkyard. I need your help...
The smock problem started when I was driving on an Autobahn in Germany. Van fully loaded and was going ~150 k/h, Suddenly went to limp mode and black smoke. Pulled over and shut the engine off, read errors and had Turbo overboost condition P0234 as well as Turbocharger boost control position sensor P2563,EGR vaccum regulator solenoid circuit P1409, U0121, and P1103
Went to Bosch workshop and the guy just felt the actuator arm and said it has excessive slack. you need a new Turbo. 1100 EUR. I couldn't afford it, so I spent the night in Germany and took the actuator apart and shimmed it tight with a thin washer and continued my trip, But it happened in France and Switzerland again. But I was driving more careful.
Back to Norway again, I took it to dealership and they charged me 120 EUR just to say I need a new engine! the engine is too old and that's why I have the black smock problem! They didn't even mention anything about the turbo.
Took the van to another workshop and after 2 weeks they changed the EGR and oil and air filter and still the same...
Driving 110 km/h on a highway on a cold day, suddenly the hose between turbo and intercooler exploded, this time i got underboost...
Changed the hose the day after and took it to another mechanic and they said injectors are the problem, they're wornout and that's why you have overboost and smoke, get them overhauled and that should do the trick. I did a leakoff test by myself and here is the results.
So took the injectors out and sent for refabrication, after 3 weeks they said it's impossible to fix these. I need to buy new ones... Bought 4 brand new ones and washers and bolts and changed them, still black smock...
Took a time and opened up the whole ducts and intercooler and everything in between. Had a lot of carbon deposit
washed them all to no avail
Inspected the houses and seals and nothing is leaking after turbo. MAP sensor seems to work normally under vaccum and MAF changes voltage after i blow on it.
PRV seems to be fine, tested by pulling out the connector and there's no leak (maybe one drop and then stops)
I don't know how to check SCV
Didn't do a compression test, don't have the equipment
a couple of days ago it was -15 deg and van starts just fine. always starts very easily, even without the Eberspächer heater on
Also has new glow plugs. and new battery
3 things that may or may not be related:
Please watch this video. When I uncap the oil inlet, I can feel air pumping out (but it's not pressurised at all)
https://youtu.be/sj5fEqYRqMw
Also, I have bobbles in my fuel pipes, I assume it's not normal, or is it a self bleeding common rail?
https://youtu.be/TKcIWldt_gU
and the last mystery, I'm not sure what this cable and attachment bracket is, but mine is broken. I assume it's just a non conducting piece of plastic and more like a cable holder. Is it?
