Does it have an EGR cooler .. is it possible for water to run into the cylinders if its faulty.. would that make it hard to start .. and the starter motor sometimes inoperative.
metalworker0 wrote:Does it have an EGR cooler .. is it possible for water to run into the cylinders if its faulty.. would that make it hard to start .. and the starter motor sometimes inoperative.
tompe wrote:I would say when it had pump and injectors I not heard about learns before so couldn't be 100 percent on that wot dose it entails
tompe wrote:Thanks for the reply what is the next step for a injectors and pump learn
tompe wrote:No going to if I can find someone near me that can do it
tompe wrote:Hi all sorry for late reply but got a learn done last week there are no faulcodes at all now but still a pig to start been told to change scv and pressure regulator on the rail would this be ur next steps
