Help turning off airbag light
Postby trannynick » Thu May 14, 2026 2:05 pm
Hello all. Its MOT time and the airbag light is on, now my reverse light setup is corroded and knackered, i understand this could trigger the airbag light, however i have used forscan and its not giving me any airbag modules or codes for the airbag light, do i need to do something specific, or doesnt the moduie exist? Thanks all.
trannynick
Re: Help turning off airbag light
Postby sentenza13 » Fri May 22, 2026 10:37 am
You can connect a 2 ohm resistor to the airbag and make the warning light disappear.
MK6 2003 TDDI 125ch
sentenza13
Postby trannynick » Mon May 25, 2026 8:36 pm
sentenza13 wrote:You can connect a 2 ohm resistor to the airbag and make the warning light disappear.
i will look into that, thanks
trannynick
