Gearbox issues fifth gear
Postby schlabbadibabba » Fri May 29, 2026 8:22 am
Hi everyone,
I’ve got a problem with my 2010 Ford Transit with the 5-speed gearbox.
When driving in 5th gear, the gear shifter vibrates and there are grinding/rattling noises coming from the area around the shifter. However, if I gently push the shifter a few millimeters to the right while driving, the noises disappear completely and everything sounds normal again.
The gearbox shifts smoothly through all gears and none of the gears pop out so far.
Has anyone experienced something similar or knows this issue?
I already changed the gearbox oil as a precaution, but the noises are still there. There were no metal shavings in the old oil either.
schlabbadibabba
Re: Gearbox issues fifth gear
Postby knobby1 » Fri May 29, 2026 9:32 pm
FWD or RWD..?? You don't say which you have.
The Transit gearboxes are fairly robust in general.
Lord Knobrot (Smithy)
Postby schlabbadibabba » Sat May 30, 2026 7:24 am
Oh yes, it's a fwd
schlabbadibabba
Postby knobby1 » Sat May 30, 2026 10:05 pm
schlabbadibabba wrote:Oh yes, it's a fwd
Check all the CV joints, gearbox mounts and the bearing which supports the right side drive shaft at the back of the engine.
Postby schlabbadibabba » Mon Jun 01, 2026 7:26 pm
Could it also be that the cable bushings from the gear selector cable are broken? Or something from the gear selecting mechanism?
Can check everything later this week
schlabbadibabba
