Hi,
Just wondering if anyone knows, if there is a fault with the immobiliser on MK6 2.4 does it allow the engine to crank but not fire up? Or does it stop the engine from cranking completely?
Altransit wrote:I suppose it would depend on what the fault is, but if you try and start with the wrong key (for example) it won't crank, and the red LED will flash furiously.
AlexPGA1992 wrote:Hi,
tranmx2 wrote:AlexPGA1992 wrote:Hi,
Don't know re' above q.
The following might be of help:
immobiliser on MK6 2.4 - g search.
AI Overview
+5
A rapidly flashing, or solid,
PATS immobiliser LED on a MK6 (2000–2006) 2.4 Ford Transit typically indicates a failed key recognition (transponder issue), low battery voltage, or a faulty transceiver coil. Troubleshooting steps include trying a spare key, checking fuse 34 (interior panel), or disconnecting the battery to reset the system
immobiliser on MK6 2.4 stops engine cranking - g search
AI Overview
A MK6 2.4 Ford Transit (2000–2006) immobilizer preventing the engine from cranking—often accompanied by a rapidly flashing red light on the dash—is
frequently caused by a lost key code, faulty transponder, power supply issue, or system communication failure. Unlike issues where the engine cranks but won't start, a no-crank immobilizer issue usually means the ECU is not releasing the starter circuit.
viewtopic.php?f=5&t=220080 - When light was out turned the key to crank - no success- engine cranks but does not start. ... Could a faulty instrument panel be causing the - for a read.
AlexPGA1992 wrote:Cheers, we have the PCM not communicating with the PATS and the fuel pump malfunction DTCs to boot. This is an ongoing issue, we are checking the wiring under starter which is a common fault but still non the wiser.
AlexPGA1992 wrote:Altransit wrote:I suppose it would depend on what the fault is, but if you try and start with the wrong key (for example) it won't crank, and the red LED will flash furiously.
I have no crank or fire, but full working electrics with the key. The red triangle immobiliser light, seems fine on the first key turn, but on subsequent turns the light will flash like the clappers.
firewalker wrote:Follow uo:
Replaced the transponder ring, ignition switch, relays and the barrel - no result.
Speculating it might be an earth problem now.
