Crane did not fit with hook/chain traveller.
Not the best way to do it but it worked.
On the gearbox are two ferals which possibly combined with the splines on the drive shaft make it necessary to pull the engine away from the gearbox without the engine being moved too high, low, side to side.
Better to use the crane on level smooth concrete. You'll likely find you cannot prevent it going with gravity. The crane goes in the sum of the directions of its wheels. I dug a shallow trench to get under and a level area to have the crane on used shuttering ply to cover the ground and provide a reasonable level smooth area. Had the van on planks on top of the raised ridged soil and had ply under the van to slide on. Better to remove the front X member. As can be seen in image it was a jury rig.
Later to put the rec eng in cut away the end of the crane arm to make a hook type end and get it further in. Used different method to get the eng in.
