CLUSTER WENT BLANK
CLUSTER WENT BLANK
Postby gsc1ugs » Fri Aug 07, 2026 11:11 am
I was dropping stuff off in my tipper mk7, when i started van, nothing was reading, speedo revs fuel gauge just 6 lines on lcd window, i stopped waited then started then it came on but MIL light come on with loads of dtcs. i used forscan remove then everything was fine, this morning mil light back on, cluster is working anyone experienced this before?
gsc1ugs
Re: CLUSTER WENT BLANK
Postby tranmx2 » Fri Aug 07, 2026 12:42 pm
Better to show yr of manufacture etc etc.
Likely battery went low - can cause lots of dtcs. Likely coursed a U dtc. Resetting/deleting/removing dtcs does not solve the problem. Can be done to clear Forscan and scan again see it they come back. Previously set can be reset.
Could also be disturbance - box up and down - ram in and out - moves a harness/connector. Harness wires for lights are moved by activating the box.
tranmx2
Postby gsc1ugs » Fri Aug 07, 2026 1:37 pm
This is today, not as many
gsc1ugs
Postby gsc1ugs » Sun Aug 09, 2026 9:00 am
Each day i have clear dtc, i would assume air flow sensor is broke… i will get one answer update
gsc1ugs
Postby tranmx2 » Sun Aug 09, 2026 11:23 am
The DTC iforms you there is a problem - you need to find out what that problem is.
Clearing the DTC does not fix the problem.
The problem can be a damaged wire, dirt in/on the sensor (don't use a rag to clean it), there can be other associated problems electrical/mechanical, other things like a broken pipe or blocked filter, loose fitting.
Some problems are easy to fix other's are not.
tranmx2
Postby gsc1ugs » Sun Aug 09, 2026 11:32 am
Ive looked at it, very clean, for £1o on ebay is worth the go
gsc1ugs
Postby knobby1 » Sun Aug 09, 2026 8:17 pm
gsc1ugs wrote:Ive looked at it, very clean, for £1o on ebay is worth the go
90% of MAF and MAP sensor issues on Mk7's are due to bad wiring and/or a poorly EGR valve. The sensors themselves rarely fail.
Far too many MAF & MAP sensors are replaced for no reason.
Lord Knobrot (Smithy)
Postby andz327 » Tue Aug 11, 2026 2:08 am
mass air flow problem wouldn't cause cluster problems and usually thats battery related which can triggers faults elsewhere
andz327
Postby gsc1ugs » Tue Aug 11, 2026 8:24 am
It hasn’t repeated, may of just been a glitch
gsc1ugs
Postby gsc1ugs » Fri Aug 14, 2026 9:00 am
Put new MAS in yesterday morning DTC has not come back on driving about all day
gsc1ugs
Postby gsc1ugs » Thu Aug 20, 2026 9:52 am
One week later no codes relating to MAS
SOLVED
gsc1ugs
