I've been saving for a new clutch/flywheel kit for some time knowing its inevitable.
Today the rest of it went, not sure if its just the release bearing or whatever but limped it home in 3rd
My question is what would you all recommend as far as the flywheel goes, I've heard solid mass flywheels have longer lifes, if you can accept the power delivery may not be as smooth (after all this is what the dual mass was designed for - until it breaks xD )
It's a mk6 '03 2.4 rwd 5 speed with the towing ratio axle, i'm assuming this is the original clutch and flywheel as i have no service history for the van whatsoever. If it is original, it's covered 120k miles so i don't think it's done too bad at all!
