alarm
alarm
Postby leemac » Tue Dec 13, 2005 11:01 pm
i have just had my y reg 350 td lwb tranny serviced and the mechanic told me that the hazards should flash when the remote is pressed to activate the alarm,can anyone tell me if this is true??????and if so why mine don't??
leemac
Postby stevew » Wed Dec 14, 2005 12:59 am
Is it an aftermarket alarm or the standard ford one?
The standard one on our works van certainly flashes the indicators.
Steve
stevew
Postby ghplumb » Wed Dec 14, 2005 2:55 am
Press the arm / lock button twice
Once to lock 2nd is deadlock & alarm on mine
Alarm only sounds the horn not a siren on factory fitted unit
ghplumb
Postby leemac » Wed Dec 14, 2005 4:09 pm
alarm is factory fitted but on second lock the lights don't flash but the doors do double lock!!!
leemac
Postby ghplumb » Wed Dec 14, 2005 7:10 pm
Are you sure it has one ?
No one else I know has a Ford one fitted I chose it as an extra option
I dont think they were ever a standard fit
Might be wrong though
ghplumb
Postby Nighthawk » Wed Dec 14, 2005 9:49 pm
The indicators should flash twice regardless of alarm fitment.
It's to confirm the double locking.
The alarm also does have seperate sounders for the alarm, they just sound like the horn. Depending on build you'll either find them inside the "B" pillar near the seat belt reel, or they're in the doors.
If yours isn't flashing, but the locking is working, have a look at the fuses.
you'll find them by looking under the dash on the drivers side.
look directly above the brake pedal, you'll see a loom running to the back of the instrument cluster, somewhere along that loom you'll see 2 fuse holders taped to the loom. They both have 15amp fuses in of the larger type, so you can't nick some out of the other fuse box. I suspect one of them is blown.
Nighthawk
Postby leemac » Thu Dec 15, 2005 8:51 pm
thanks nighthawk just like you said blown fuse.....
leemac
Postby Nighthawk » Thu Dec 15, 2005 9:19 pm
8)
Glad it's sorted
Nighthawk
Users browsing this forum: Google Adsense [Bot], sandancers
