Cruise control unit
Cruise control unit
Postby VJ 6 Aus » Thu Jun 22, 2006 3:36 pm
Evening all any tips on where I can get a factory cruise control unit for my Mk6 its a 6 sp manual 135t350 and has anybody used one
VJ 6 Aus
Postby AndyG » Thu Jun 22, 2006 6:42 pm
There is someone on here that fitted cruise control I'll try and find it unless someone else can before me :!: :D
Postby MrMPuk » Thu Jun 22, 2006 6:51 pm
Postby AndyG » Thu Jun 22, 2006 6:53 pm
What can I say :!: :lol: :lol: :lol:
Postby MrMPuk » Thu Jun 22, 2006 7:35 pm
That was a 9 minute reply time, I think i've let you down! :(
Postby 100ps_drw_hicube » Thu Jun 22, 2006 11:38 pm
MrMPuk wrote:That was a 9 minute reply time, I think i've let you down! :(
very poor :evil: :evil: :evil:
:lol: :lol: :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby VJ 6 Aus » Fri Jun 23, 2006 6:55 am
Thanks for that is there a Ford Factory unit available or are they all OEM units
VJ 6 Aus
Cruise control
Postby Terry » Fri Jun 23, 2006 8:03 am
I would assume there is a 'factory' one but don't know for sure.
Mine came from & was fitted by a company Conrad Anderson in
Birmingham, the unit they used was not OEM either, it was a Dutch made unit.
I am away for a week now, but will get piccies if you want them.
Terry
Pallet Puller
Terry
Postby VJ 6 Aus » Fri Jun 23, 2006 9:55 am
Thanks Terry,
I can get OEM units but I,m led to believe there is a "leather steering wheel and cruise control " option which I assume has the buttons on the wheel is that something availble on the Tourneo over there? or is it availble on the Transit maybe the Exec pack?
VJ 6 Aus
Postby Nighthawk » Fri Jun 23, 2006 9:43 pm
Transit has never had factory specc'd cruise control until NOW ;)
It's now an option on V347 and V348 Transits.
The wheel you might have seen was probably from a durashift ASM vehicle and the 4 buttons are for gear change up and down.
Transit.........Job done
Nighthawk
Postby VJ 6 Aus » Sat Jun 24, 2006 12:16 am
Thanks for that Night hawk,
I have been reading some of your other posts and deduced that you might be employed by the Blue Oval, the Mark 7 looks to me like a "facelift model" I wonder if the new Cruise will fit my 9/05 built Mk6?
would you now if the front fogs are normally switched by the "pull" switch in the headlamp switch or is there another switch and where does it fit and what does it look like cause we don't get that option over here and I will fit some very shortly so will need to source the switch and lights from the UK
VJ 6 Aus
Postby motorwise » Sat Jun 24, 2006 1:07 am
VJ 6 Aus wrote:Thanks for that Night hawk,
I've got front fogs on mine the switch just pulls out two notches instead of one - same switch on focuses etc if you have them over there they more commonly have that option - hope it helps
http://www.motorwise.net
motorwise
Postby VJ 6 Aus » Sat Jun 24, 2006 7:30 am
Great thanks for that, Focii we ahve plenty of one 2.0 zetec in the driveway as it happens I wonder if she will get used just twisting those two wires together :lol:
VJ 6 Aus
Postby Nighthawk » Sat Jun 24, 2006 6:16 pm
The engine control module is different on the new transit along with the rest if the fuel system so I don't think you'll be able to retro fit the module from one to another.
I think you'll be better off sourcing an aftermarket kit.
Maybe I could set up a parts supply business sending all our good bits out to Oz :)
I'm surprised the Transit over there didn't get the front fogs, the Australian post office pack got pretty much everything else.
mind you...do you get much fog down there?
Nighthawk
