EGR gubbins
EGR gubbins
Postby fastmower » Fri Aug 11, 2006 8:29 pm
Can someone clever give me a quick run-down on the EGR system?
My truck is a 51 plate 2.4 90PS. I've searched EGR in this section of the forum but not found a deal.
Basically - what's it for?
How does it work?
What happens if it's removed?
Is removing/disabling it a good or bad idea?
Is it the cylinder attached to the rod on the top of the unit in this pic here:
Thanks in advance!
Andy
From four vans to two :-(
1997 Mk5 County Transit 4x4
2003 Mk6 ex RAC 330 SWB
fastmower
Postby Guy88 » Fri Aug 11, 2006 8:38 pm
The EGR is exhaust recycling and it is used to feed exhaust gases back into the engine to reduce emissions
It is a valve between the intake and exhaust manifold and is vaccume operated and i guess it has a sensor for the ECU
If it is removed the ECU will give an error code and probably go into limp home
Dont think you can remove it on the MK6
The cylinder in the pic is the turbo wastegate actuator which controlls the boost pressure by opening a valve in the exhaust side of the turbo. when it opens it allowes gas to bypass the turbo therefore lowering boost
Hope this helps :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
