52 Plate 2.4 Will not start ....... HELP !!!
Postby 100ps_drw_hicube » Wed Aug 16, 2006 10:40 pm
ok had better not post on here at all then :shock:
100ps_drw_hicube
Transit Abuser!!
Postby Nate » Tue Sep 05, 2006 8:58 am
Fuel pump was the problem ......... Nothing wrong with pcm.
Am suspecting the power has been decreased, as it doesn't seem the same power ...... Was struggling yesterday to do just over 70 :?:
Nate
