Azer van man wrote:No all i got was the locking nut remover, i said to the local stealer that they should of supplied spacers or something like that cos what i'll have to do now if they replace them is keep the damaged ones so it dont happen again
mk5's are 12mm mk6/7's 14 i believeMarkM wrote:What you need is a set of nuts from a MK6 steel wheel as the stud will go through the nut with no damage, assuming they are the same thread. If not the same thread, then you need that 'type' of nut but with the correct thread.
Luke wrote:mk5's are 12mm mk6/7's 14 i believeMarkM wrote:What you need is a set of nuts from a MK6 steel wheel as the stud will go through the nut with no damage, assuming they are the same thread. If not the same thread, then you need that 'type' of nut but with the correct thread.
MarkM wrote:Luke wrote:mk5's are 12mm mk6/7's 14 i believeMarkM wrote:What you need is a set of nuts from a MK6 steel wheel as the stud will go through the nut with no damage, assuming they are the same thread. If not the same thread, then you need that 'type' of nut but with the correct thread.
Ok well I did think I had read about the threads being different, it was the 'style' of nut I was getting at as afterall you can get alloy wheel nuts with the collar that allow the stud to go through but are meant for alloys with a covering centre cap.
Azer van man wrote:The latest on this saga is Frauds now say that the nuts have been damaged because the tyre fitter removed them with an air gun but i have checked with tyre fitter and he didn't use the air gun. Quite how this can damage the nut i dont know, it was doing them up that was the problem HEEEELLLLLLLLOOOOO FOOOOORRRRDDDDDS give me strength![]()
