Help, mk6 2.4 90psi snails pace no boost
Postby matt171289 » Tue Feb 24, 2015 5:35 pm
Hello people, i have a mk6 2.4tddi 90psi 2001 350 transit, the transit has had new turbo, new fuel pump, fuel lines checked, wastegate checked, crank sensor replaced, timing chain replaced and timing checked, and its still no boost, there is pressure from the turbo all the way up to the egr, (egr has been blanked off) the manifold has been checked for cracks, so where the boost is going i do not know, the van is also cutting out avery 3days after its been dio read, each time its coming up with Pump fult, as soon as the van stops, it will start on the button, and tick over and rev brilliantly, till i engadge the clutch and set off, then it will cut out, im out of ideas on this problem as like i say the fuel pump and lines and filter and housing have been replaced, turbo has been replaced, aswell as the boost pipes, eger has been replaced and blanked, timing chain has been replaced timing was also checked, crank shaft sensor replaced, intercooler pressure sensor has been replaced, all with brand new ford genuine parts, HELP!!!! lol
matt171289
Re: Help, mk6 2.4 90psi snails pace no boost
Postby bazw » Tue Feb 24, 2015 7:54 pm
cant help but I know those that can will ask what the codes were. posting them will speed them allong ;)
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby karl » Tue Feb 24, 2015 8:23 pm
its a 90 mine is dog sh*t slow on take off,but flyes on motorways but then dies on hills but a carry just under 3.5 tons in it at any one time ?
what you carry ?
karl
Tranny Lover!!!
Postby matt171289 » Tue Feb 24, 2015 8:42 pm
hey, im lucky if i get 45mph outa her on flat road, going up the orwell bridge im lucky to get 25mph, i carrry disco equipment and also about 3 fruit machines, the pupm code i dont know but it read as the solenoid?? but that was all new with the pump
matt171289
Postby karl » Tue Feb 24, 2015 8:51 pm
if you had a new recon pump take it back ?
you get 6 months warrenty with a recon pump
karl
Tranny Lover!!!
Postby matt171289 » Tue Feb 24, 2015 8:57 pm
its a brand spanking new on form ford, after iv stuck my dio tool on it nd cleard the code it stops cutting out for about three days unless i push it around a corner 2 fast, then it flags up again, so im looking at the wiring loom next, if not i think a manual pump, its just that boost and im not convinced the boost and the cutting out are connected
matt171289
Postby karl » Tue Mar 03, 2015 10:54 pm
old post but recent
but when you changed pump did you time it up correctly ?
and how did you change the pump
karl
Tranny Lover!!!
Postby matt171289 » Sun Apr 05, 2015 12:17 pm
hey, ford done the pump, and turbo, and intercooler, when pump was done they also put a new chain on, and said the timing was off by 3 teeth, but its still no better, ford are stumped and before the work was carried out they said that they take no responsibility if it dont fix it, as they tried diffrent bits and nothing was making it any better, they also checked for a limiter on the ecu, but non found, we are all stumped, but iv spent to much doe on this van to concider getting rid
matt171289
Postby matt171289 » Sun Apr 05, 2015 1:57 pm
seems like its in limp mode constantly with or without fult codes stored
matt171289
Postby MinorMatt » Sun Apr 05, 2015 4:49 pm
Have a chat with dieselhead123 or andypdq about a mechanical pump...
Postby andypdq » Sun Apr 05, 2015 8:57 pm
MinorMatt wrote:Have a chat with dieselhead123 or andypdq about a mechanical pump...
If your basic engine is sound, a mechanical pump is a guaranteed, simple cure, lots more power than a standard 90, same fuel economy, no more limp mode, code reading or never ending electronic faults, which the "experts" at Ford don't seem to be able to fix.
PM me if you're interested. :D
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby Jim Archer » Sun Apr 05, 2015 10:21 pm
Linkage on EGR flap broken or stuck closed.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby matt171289 » Sat May 23, 2015 2:26 pm
Still no further forward to finding the issue, i have asked around, some people are say "stuck in limp home mode" some people are saying this " if this a pre common rail pump it sounds like pump timing is out which is why it's giving fault code for crank sensor and fuel pump" the seccond one makes more sense, but i dont know if i have a pre common rail pump,
matt171289
Postby ake » Wed May 27, 2015 8:43 pm
matt171289 wrote:Still no further forward to finding the issue, i have asked around, some people are say "stuck in limp home mode" some people are saying this " if this a pre common rail pump it sounds like pump timing is out which is why it's giving fault code for crank sensor and fuel pump" the seccond one makes more sense, but i dont know if i have a pre common rail pump,
90ps is NOT common rail
Postby matt171289 » Thu Jun 04, 2015 5:56 pm
also the batter is brand new, and always fully charged, i went in to hospital, for a week, and its as dead as a door post, soim now thinking what ever is draining the battery is also the fault why ist on the go slow, the battery in my eyes should last three weeks, as its a good brand and all the "silver calcium" crap
matt171289
