Is in on top of air box or intercooler?
Looking on forscan my sensor is showing -40c.
It's supposed to of had a sensor changed but mechanic said mass air and invoice said air temp.
Sent from my SM-A107F using Tapatalk
Give the wires a good check for damage down to where they go into the loomwalt1984 wrote:Fitted it, still the same fault.
High idle and heated screen decided to switch on a 10c.
Still got a -39/40 IAT.
My van only has the sensor in the air box (mass air and temp?) And a green charge temp in the out let side of the intercooler.
I'm starting to wonder if when the van has been worked on they have pulled the wires for the mass air flow and it's not connected in the multi plug anymore as the problem started after then or, does the butterfly valve on the bottom of the inlet manifold have a temp sensor?
Traced wires to where they join the main loom behind passenger head light, looks fine.andz327 wrote:Give the wires a good check for damage down to where they go into the loomwalt1984 wrote:Fitted it, still the same fault.
Sent from my SM-G975F using Tapatalk
jonb1 wrote:in live data is the maf switching i only ask this as had a few now with wiring loom faults? if you put the hella maf back in what temp reading do you get then, have you had a look at wiring from maf plug to where it joins main loom by head not plug by head light but where maf wires go into main loom if that make sense ? had broken wires in that area, also be worth doing a continuity test on maf wires through to ecu & think 1 goes to fuse box but could be wrong
hope that helps
Altransit wrote:Did you ever manage to sort this Walt?
