Sorry for the long novel, but i don t see how to summarize that more.
Context:
2.4 tdci 140 2008
Camper so big load (near 3.5T)
now 200 000km
The problem begin i would say near 6/7 year ago or something like that. (truck was near 140 000km i would say)
One day the check engine turn on.
At this time i do not have anything to check the log as i never had any problem with it.
We go to the ford dealer who do the car maintenance on it.
After a check, it says it's the EGR valve who die, so they replace it for a brand new OEM FORD.
1 year after, check engine turn on again.
I buy the necessary to check log ==> P0299/0234. (+ MAP and MAF related value)
I clear the DTC, could drive 2000km, then it come back again. So more then 2000km with no code, and it comes again.
I replace the map and maf sensor to be sure that all is ok here and because i got bad cold temp on IAT2 (that solve this point) + incorrect DMD and read value)
But it change nothing, the code comes back near 2000km later.
More and more the check engine light (P0299) comes early, every 1000, then 500, then 200 then all the drive.
Between the error, everything seems to be ok, the transit got normal performance, everything is ok.
When check engine come, just before i could notice some "lag" like it took time to charge, but it's the same when check engine comes on, and that comes nearly after...
I change the mechanic because i was not satisfied of Ford (for a lot of reason on other cars too) and go for a local mechanic.
It tooks time and check, and says that EGR has died again. He choose a metalic EGR PIERBURG (brand new) and change it.
It works like a charm 2000 or 4000 km, then again P0299 come back. (i don t remember if they were P0234 this time)
We try an hydrogen cleaner even if for me it brings nothing (but well let's try...) and it change nothing. P0299 come backs 2000km later.
Like before, between the error code, the transit drive normally.
The things that always warn me that that something is wrong with EGR is that the map and map_dmd value are never in range (map_dmd are totally wrong) same for maf and maf_dmd.
Like i have already reported there:
viewtopic.php?f=5&t=217842
At this point we send the injector to control, they were all out of range.
We replace them, code them, and do the pump and injector learn procedure.
Everything was right, the transit was more reactive at low rpm and got more power at more then 3000rpm so seems to be good!
But the map and maf value are like before always totally wrong. But well no error code so...
Map readiing value is "normal" at more then 1.34 boost value if i remember well so turbo seems to boost normally.
I drive 3000 km, no more error code, was thinking that everything was solved...
Then i went for a refuel, start the engine again, accelerate (not full throttle but near 80%) and immediately notice some "hesitation" like if EGR were closing/opening and make some "wave" on the acceleration (difficult to describe)
Then the limited performance come back again, with check engine on...
I check the error code, and got all the one related to EGR... P0299/P0234 + MAF and map related error code + error that are directly related to the EGR (solenoïd position or other error code, i could give you the list but no doupt there).
If i remove the error code, 2 stay (solenoid position and one other for EGR), and after a period, all comes back and check engine line come back.
Some more information:
I never drive at low rev, i drive at more then 2000RPM, climb hill at more then 2500 rpm (long hill at more then 3000), as it's a camper, it's never used in town and it always make long travell so normally not something that could clogued an EGR.
The majority of our travel are driving at 110km/h on highway so at more then 2700rpm in six. Even at 80km/h we are at more then 2000RPM in six.
I regularly make full throttle acceleration at more then 3000 RPM (until 4000) to clean the engine.
And even with that, that could not explain why everything was ok with me driving for more then 140 000km, and now with the same driver kill 3 EGR in 50 000km.
They is no smoke on idle, or acceleration. Idle is stable.
We use diesel station not supermarket station. The only case where we do not know what it is when we travel in outside our country, we do not know if it's supermarket or diesel station.
What are new:
VCV+PRV (because of poor idle, and it solve the problem)
4 new injector (because out of nominal range after test it)
MAF and MAP sensor
and of course EGR twice...
Fuel filter + air filter are new of course and has been changed a lot of time since the problem appear
So it seems that knobby was right, i still have problem with the EGR, but could not explain why .
Do you have an idea of what could bring such result????
At this moment, we are look to find a mechanic far away from home, to check the EGR... Yep nice holliday....
Thank's.
