Second Battery.
Second Battery.
Postby Daveyboy » Fri Sep 11, 2009 7:18 pm
Had a call-out last night, I've got 2 outward facing worklights fitted inside back of van, left them switched on all night, like a t**t. Went out to unlock it this morning and central locking was not working, the drivers door unlocked on the key but nothing else. Turned the key in the ignition and it fired up first thing, only problem was that I had to re-enter the radio code. What a good idea the second battery is to forgetful old farts like me :lol:
Daveyboy
Re: Second Battery.
Postby winterheating » Fri Sep 11, 2009 9:04 pm
thats handy.
are you going to take the flat battery off and charge it proparly, cos it will never be fully charged if you just let the alt do it.
winterheating
Re: Second Battery.
Postby Vee4 » Sat Sep 12, 2009 9:52 am
Daveyboy wrote:What a good idea the second battery is to forgetful old farts like me
Good to hear that it worked as intended - I ordered twin batteries on the new Mk7 mostly because I was concerned about the amount of stuff that's on all the time whether you like it or not, draining the battery while it's parked. It might save me from myself too, as in your case.
winterheating wrote:are you going to take the flat battery off and charge it proparly, cos it will never be fully charged if you just let the alt do it.
Can you explain in more detail why that would be?
'69 Mk1 V4 :) >> '76 Mk1 V4 :) >> '84 Mk2 OHC :wink: >> '97 Mk5 Banana :D >> '09 Mk7 TDCi 8)
The van in front is a Transit. It might be my Mk7 - follow the trail of rusty water: Diary of an Ordinary Van
Vee4
Re: Second Battery.
Postby winterheating » Sat Sep 12, 2009 8:16 pm
cos once a battery is flat the alt will top it up to power, but it will never be at full capacity till its trickle charged correctly.
if you test a battery and its 12.6 it will be 20% capacity, but if it where at 12.9 it would show full capacity.
(dont know if them figures are correct but you get the idea)
winterheating
Re: Second Battery.
Postby tyman » Sat Sep 12, 2009 8:53 pm
Can i ask how you have a 2nd battery fitted as would like to fit extra lights in rear on my 05. Is it just a case of linking neg. & pos together? cheers :)
tyman
Re: Second Battery.
Postby Vee4 » Sat Sep 12, 2009 9:41 pm
winterheating wrote:it will never be at full capacity till its trickle charged correctly.
Would a good, long run (or several long runs, eventually) not do the trick? Those batteries are rather inaccessible under the seat! Could you trickle charge the second battery 'in reverse' by connecting a charger to the 'cigar lighter' socket while the van is parked? I have a solar panel that is supposed to work that way.
Vee4
Re: Second Battery.
Postby sc_BK » Sat Sep 12, 2009 9:44 pm
tyman wrote:Can i ask how you have a 2nd battery fitted as would like to fit extra lights in rear on my 05. Is it just a case of linking neg. & pos together? cheers :)
If you wire it up like that they will both run down at the same time.
You could use some kind of split charge system or just an isolater switch on the pos cable
sc_BK
Re: Second Battery.
Postby winterheating » Sat Sep 12, 2009 9:53 pm
i was thinking of fitting a few of them solar panels to the roof of my van, taking the load off the alt and helping extra lights.
winterheating
Re: Second Battery.
Postby Vee4 » Sat Sep 12, 2009 10:20 pm
See Jezclayton's post for the kosher way to do it on a Mk7:
viewtopic.php?f=5&t=29055&start=0
This kind of installation is very common on campers. The following site has a good description of the two common methods of keeping the batteries from talking to each other (i.e. relays or diodes):
http://www.marcleleisure.co.uk/store/circuits.php
If you search the Forum for 'second battery' you will find hundreds of references:
search.php?st=0&sk=t&sd=d&keywords=second+battery
Vee4
Re: Second Battery.
Postby Daveyboy » Sun Sep 13, 2009 11:47 am
I thought the second battery was fitted as standard to all mk7's, don't think mine was specifically ordered with it if not :?
Daveyboy
Re: Second Battery.
Postby Vee4 » Sun Sep 13, 2009 12:37 pm
Daveyboy wrote:I thought the second battery was fitted as standard to all mk7's, don't think mine was specifically ordered with it if not
It's an option on 260, 280 and 300 FWD models. If you order the rear auxiliary power point (sounds grand but is in reality a cigar lighter socket in the right rear door pillar), the second battery is added automatically.
Vee4
Re: Second Battery.
Postby Daveyboy » Sun Sep 13, 2009 8:14 pm
Ah that explains it mines a 350 and has a rear 12v socket.
Daveyboy
