removing cat - updated mk6
Postby nitroman » Mon Apr 24, 2006 11:18 am
25th april am van is goin in for de cat, will let you know what it cost and if it improves performance
nitroman
Postby Valsheda » Mon Apr 24, 2006 5:19 pm
Will this cause you any probs with the emitions come MOT time ?????
Valsheda
Top Tourneo Owner
Postby belly » Mon Apr 24, 2006 5:22 pm
ive been told i hope its true!!!!!! you dont legally need a cat on diesel :D
belly
Kaiser Chief
Postby Valsheda » Mon Apr 24, 2006 5:26 pm
Yeh i have heard that too, but not too sure how true it is, if i had a diesel van i would do away the cat, when i got my s/steel system fitted i had the choice of if i wanted a cat bypass pipe, i wish i had got it done :lol:
Valsheda
Top Tourneo Owner
Postby belly » Mon Apr 24, 2006 5:40 pm
as i say i hope its true pretty sure it is my cars one has been removed it was cheaper to remove it than replace it when some kids left a brick in the road and i hit it collapsing the honeycomb inside :evil:
belly
Kaiser Chief
Postby belly » Mon Apr 24, 2006 5:42 pm
had a (sports cat) big empty one ii think on a clio 16v i had made a massive difference :D
belly
Kaiser Chief
Postby Valsheda » Mon Apr 24, 2006 5:49 pm
Sounds good, where do you get one of them from 8)
Valsheda
Top Tourneo Owner
Postby belly » Mon Apr 24, 2006 7:37 pm
i got that from demon tweeks it was a magnex one i think :? dont know if they would list one for a transit tho :)
belly
Kaiser Chief
Postby Valsheda » Mon Apr 24, 2006 7:48 pm
belly wrote:i got that from demon tweeks it was a magnex one i think :? dont know if they would list one for a transit tho :)
I new i should of gone for the bypass pipe, perhaps i could get it added into the system at a later date :P
Valsheda
Top Tourneo Owner
Postby belly » Mon Apr 24, 2006 8:11 pm
yeh im sure its possible could get a nice easy unboltable one with nice stainless bolts so if it had to come off once a year maybe :wink: its not seized on :D the upside is if you wrap up your cat and put it in a nice dry dark place(airing cupboard mrs loves it really) you dont have to buy a new one when it knackers the price for a new cat for my car was around 260 +dreaded :shock: or 350 for a custom straight thru full system stainless one silencer from down pipe it just made sense really :D and it sounds nice and throaty with loadsa turbo whistle :lol:
belly
Kaiser Chief
Postby gazza » Tue Apr 25, 2006 1:39 am
http://www.motuk.co.uk/manual_740.htm
all you need to know about derv emmisions at mot time :wink:
gazza
verdict!
Postby nitroman » Wed Apr 26, 2006 10:47 am
well pleased overall! it feels like 200 kgs of weight has been lost, you have to push the go pedal less to make it shift, the turbo just spins instantly and the torque comes in earlier and goes right through the revs much smoother.i tried 0 - 60 this morning and there is a definate improvement but not massive but more impressive is the top end say 70mph to 110 mph which is much better!
mot issue aint a problem at the moment as they only meaure the smoke not the content of it!
fuel consumption has gotta be improved if i drive it sensibly too
nitroman
Postby belly » Wed Apr 26, 2006 9:14 pm
did you buy a off the shelf de cat? if so from where ? or was it a custom made jobbie cheers :D
belly
Kaiser Chief
Postby nitroman » Thu Apr 27, 2006 9:48 am
no i just the old one out and replaced it with the same diameter pipe, its difficult to get to the cat on mine thats why no local tuning shop would touch it.
nitroman
Postby Gunslinger » Thu Apr 27, 2006 11:39 am
Depends if your old one is knackered inside or not and if you want to hide the fact that youve messed with it, but if it goes through MOT's ok as it is, then i would have the insides suitably removed from the cat and then slide a narrow gauge (thickness) stainless tube down the inside and weld it up then refit it, so to the untrained eye it looks like its there :P
Gunslinger
Users browsing this forum: DanMK7uk, Trev_
