How to add factory cruise on a mk7 transit no pics
Re: How to add factory cruise on a mk7 transit+pics
Postby mikey transit » Wed Feb 26, 2014 2:50 pm
Can it be modified for mk7 lol
If it doesn't fit, Drill a bigger hole !
mikey transit
Postby Stacker » Wed Feb 26, 2014 3:31 pm
loot34 wrote::lol:
Well if there is a demand, I'll try to help as much as i can, a friend of the forum is a friend if mine after all.
Bear with me this is taking all my skills up.
Right i have engineered a cunning system to implement cc on the mk6.
I'm physically and emotionally exhausted, but here you go, i hope you appreciate this?
Hi there,
I appreciate the hard work you have put into making cruise control work in the mk6, I have tried this on the motorway and it works great,
However I can't adjust the speed, any ideas?
2006 Transit Jumbo 115PS - Had it stolen, written off and now brought back - SOLD!
2010 Transit Jumbo 140PS Sea Grey - Still going on 227k! - Jan '19
2005 Transit LWB Hi Top 135PS -Sold, thank god
Stacker
Postby blue estate » Wed Feb 26, 2014 3:35 pm
A chisel
blue estate
Postby soprano1982 » Fri Mar 07, 2014 8:14 pm
Bingo :D Image
soprano1982
Postby loot » Fri Mar 07, 2014 8:36 pm
Welcome to the exclusive club that was exclusive til the exclusivity was removed by hacking into the exclusive club rendering it un exclusive and therefore just a club.
But welcome anyway :lol:
Ids map here
loot
Postby soprano1982 » Fri Mar 07, 2014 9:41 pm
:lol:
soprano1982
Postby scousy » Thu Mar 13, 2014 12:39 am
ok guys ,changed the wheel have the correct bcm just need someone to do the software for me ( closer the better as I've got a tracker :roll: ) cheers...oh forgot I live in S.Wales ....
scousy
Postby garyw20 » Sat Mar 15, 2014 12:28 am
scousy wrote:ok guys ,changed the wheel have the correct bcm just need someone to do the software for me ( closer the better as I've got a tracker :roll: ) cheers...oh forgot I live in S.Wales ....
Hi. Did u have the wiring in place for the cruise control. I also hav the correct bcm but havnt checked my wiring yet.
Gary
garyw20
Postby scousy » Tue Mar 18, 2014 11:15 pm
Gary
sorry for late reply I'm working away atm , not checked to be honest , assumed because it's a 12 plate with all the other display feature's it would be already there ? is that not the case then ?
scousy
Postby garyw20 » Wed Mar 19, 2014 7:14 pm
Gary
I'm not too sure, I also have all the other features, so hoping I have the wiring to plug my steering into. I just bought a leather cmax steering with the cruise buttons. Did you have the extra plug to plug ur cruise control steering into ?
garyw20
Postby loot » Wed Mar 19, 2014 8:14 pm
There's no extra plug, the lower plug is dead, it's a dummy.
You simply unplug the upper existing plug with the original wheel then fit the cmax wheel and plug it in, it will have a red and grey wire in the middle 2 pins.
So straight swap wheels and put back together.
The wiring is on the lower under steering cowl at the outside of the squib by your bollox at pins 4 and 5.
I think anyone who wants to know if they have the wires should just look because there is no rhyme or reason as to who will and who won't have them.
Although the more toys you have then the more likely you are to have them :wink:
Ids map here
loot
Postby scousy » Wed Mar 19, 2014 10:26 pm
thanks for the info Loot will take a look on the weekend , any idea who lives the closest to me ( Newport S.Wales ) who can do the software for the cruise for me ?
scousy
Postby garyw20 » Wed Mar 19, 2014 10:29 pm
loot34 wrote:There's no extra plug, the lower plug is dead, it's a dummy.
Cheers, will have to get a look. My steering hasn't arrived yet, but I should have it by the weekend. Should I disconnect the battery wile unplugging the airbag??
garyw20
Postby scousy » Wed Mar 19, 2014 10:53 pm
Hi Gary , I took the advice of the others , didn't bother disconnecting the battery just unplugged everything under the cowling around the base of steering wheel/stalks if that makes sense ?
scousy
Postby loot » Wed Mar 19, 2014 10:59 pm
As above really, if you want to disconnect the battery it is entirely upto you, i undid the external lower squib connector, and stood out of the can to reconnect, paranoia lol.
Ids map here
loot
