how to bypass a mk7 egr valve?
Re: how to bypass a mk7 egr valve?
Postby winterheating » Wed Mar 16, 2011 8:28 pm
anyone got a copy of recent autotrader :?: , theres a small advert in the back, a company that specialises in removing EGRs from all vehicles and removing from the ecus......
winterheating
Postby SteveO » Thu Mar 17, 2011 1:07 pm
Nope. Looked in my copy nothing. Got any contact details? I suppose it would make sense that the ecu would be reading the values and after all when you remap turbo charged car you can write out certain sensors to stop error codes + cope with the extra power.
Anyway let us know.
SteveO
Postby winterheating » Thu Mar 17, 2011 2:33 pm
or maybe last couple of months, ones, its defo there just a tiny little advert,
winterheating
Postby Skippy » Sat Aug 13, 2011 8:25 am
Just found this thread. A friend in Adelaide looked at my mk7 recently.
He has some credibility, he told me to use a blanking plate with a 10 mm hole in the centre.
Aparrantely this does not activate the mil light whilst still allowing correct operation of egr with reduced gas intake. It's a job to know what the solution is but some of the senior electronic engineers that design the software for ecu's would definitely know exactly what to do in an instant. I know orbital corporation here in Perth are specialists in induction technology. Would be interesting to know the bloke who sat down and designed this system. Guess it will take time and maybe in 10 years time we will have a solution. :)
MK5 SWB 150 100ps, MK6 LWB 350 120ps
Skippy
Postby winterheating » Sun Aug 28, 2011 11:58 am
That's not blanked with a 10mm hole. Just means there's enough exhaust gas flow still so exactly the same as having it fully operational, and the egr would just open more to compensate if the 10pm hole did somehow restrict the flow. some have been doing that on Mondeos for years not realising their error.
winterheating
Postby comstech » Sun Feb 17, 2013 12:37 pm
So what is the correct way to blank off the EGR on a VM transit with out having the engine light come on?
I currently have the engine light on and codes indicate the EGR valve so I am trying to work out
1. Remove it and clean it and re-install
2. Just replace it
3. Just slide the blanking plate in, but still need to stop the EGR error coming up
comstech
Postby Guy88 » Sun Feb 17, 2013 12:42 pm
comstech wrote:So what is the correct way to blank off the EGR on a VM transit with out having the engine light come on?
2. Just replace it
blank it off and get vantuner to delete it from the engine map
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby njm » Sun Feb 17, 2013 1:09 pm
2. Just replace it
Took the gears out of my egr and had an egr delete by the VanTuner on Friday i would recommend this mod to any mk7 owner
mk7 115 with i-map + egr delete
njm
Postby Guy88 » Sun Feb 17, 2013 1:11 pm
If van tuners turned it off there's no need to remove the gears
However it will need blanking if its leaking
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby njm » Sun Feb 17, 2013 1:15 pm
Guy88 wrote:If van tuners turned it off there's no need to remove the gears
Sorry should have said that the egr was sticking so i removed the gears prior to egr delete
njm
Postby Daniel Breed » Sun Aug 14, 2016 7:46 pm
Is you van a mk 7 2.2 cdti and can you completely remove and block off the hole egr valve and just keep the sensors and electronic motor connected re routethe cooling pipes if there is any I don't want all the extra egr still there
Daniel Breed
Postby ake » Mon Aug 15, 2016 6:35 am
Daniel Breed wrote:Is you van a mk 7 2.2 cdti and can you completely remove and block off the hole egr valve and just keep the sensors and electronic motor connected re routethe cooling pipes if there is any I don't want all the extra egr still there
That'll still throw fault codes.
Postby Daniel Breed » Mon Aug 15, 2016 11:53 pm
Would an egr file delete work just took off my egr today
Daniel Breed
Postby ake » Tue Aug 16, 2016 6:47 am
Daniel Breed wrote:Would an egr file delete work just took off my egr today
Yes, that's the only way to prevent codes and warning light, by having it deleted
Postby pp5858 » Fri Aug 26, 2016 8:08 pm
What kind of tools needs for deleting it? Is there any instructions around for that or does it need some special tools?
pp5858
