by CROSSFIREROB » Mon Jun 11, 2012 7:23 pm
My problem is now fixed, and i have kicked my own teeth in several times since , now for those who have the lpg system, this is for you , when someone tells you to clean out the stepper motor , dont do what i did , i took the top off and didnt see anything else so cleaned what i had and put it back on , so i in fact cleaned f*** all, which is why it made no difference , when you take of the top of the stepper motor look out for small ball bearing sitting on the rim , then reach inside of the cylinder and pull out the cup which is the bit you want to clean that i never saw, it has o rings on the out side, take them off , clean the plastic part with spray cleaner, then put the o rings back on , then here comes the bit i wouldnt have done due to not knowing , you must spray the thing with silicone spray so it relocates without rubbing the o rings off, then put it back together and bobs your uncle you will have a good working van, this should take about 30 minutes , and will not cost you £125 that it cost me,on that note dont go to Arun Gas unless you really have to , the mechanic is a real good knowledgeable ,guy but the boss is a money orientated prick, if you have any problems after you have been to them , he will just tell you to book in again as he did with me,my van was stuttering a bit , so i rang him and he had no advice other than booking it in , total idiot, done himself no favors there .
Rockin and a rollin all day long !
