Idiots guide to IDS
Re: Idiots guide to IDS
Postby loot » Thu Apr 13, 2017 9:57 pm
Up
Ids map here
loot
Postby Airthies » Thu Apr 13, 2017 9:58 pm
Down
...Continue reading.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby mattyyoung » Sat Apr 15, 2017 9:10 pm
Hi all,
Can anyone recommend somewhere I can buy a cloned ids from?
Regards
Matt
mattyyoung
Postby Airthies » Sat Apr 15, 2017 9:53 pm
mattyyoung wrote:Hi all,
Regards
Matt
Have a read here, it's all written down if you follow it through.
viewtopic.php?t=155150
click HERE for more info.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby mike10 » Sun Apr 23, 2017 4:26 pm
I'm hoping someone can help me out here. I can't get my IDS to connect to my van.
I've installed IDS v86.04 on my laptop, following the instructions in this thread, and all seems to be working fine.
I have attached it to my newly purchased VCM2 clone and it can see that and talk to it.
If I plug the VCM into the OBD port on its own it powers up (tested for voltage at the plug, and fuse 72, they're ok), so that seems fine.
When I connect it all to the van as it should be it cannot see the PCM.
If I try and enter the details manually it says the information is invalid.
I've had a look at the configuration files and there doesn't seem to be one for my PCM.
I tried downloading it from here (https://www.fordtechservice.dealerconne ... roduct=IDS), but it says it is not found.
Codes on the PCM are as follows; (I think the first one is the key one, yes?)
AC11-12A650-BA
9HBA
DCU-201
0E142 0185A
14462170602/ECU
S/N Y5E201APLDDT
And just to double-check.... the PCM is the silver box on the nearside front wing next to the coolant tank, yes?
Does anyone have a link to the file, or a copy they can let me have?
Or have I been doing something silly and it's not that at all?
Van is a 2010 2.2 TDCi 115ps 350M FWD - (EF10AUE if you need to look it up on ETIS)
Thanks for any help.
Mike.
mike10
Postby loot » Sun Apr 23, 2017 5:41 pm
Feet ids turned on and running, connect vcm usb, did you get a prompt to update the vcm? Do it. In ids you should see green arrows top right and red vcm bottom right.
Plug it into the van obd and ignition to position 2 with lights on dash, ids should id, go to toolbox, start new session, all other and ids should then read the van pcm and tell you it is a tdci etc.
Ids map here
loot
Postby mike10 » Sun Apr 23, 2017 6:48 pm
loot wrote:Feet ids turned on and running, connect vcm usb, did you get a prompt to update the vcm? Do it. In ids you should see green arrows top right and red vcm bottom right.
Didn't get a prompt to update, but it said something about 'initializing for first use' (or words to that effect) when I first connected it if I remember correctly.
Had the green arrows and the red VCM symbol. It was showing as connected on the VCM status screen.
loot wrote:Plug it into the van obd and ignition to position 2 with lights on dash, ids should id, go to toolbox, start new session, all other and ids should then read the van pcm and tell you it is a tdci etc.
That's where I was going wrong then. As I had a VCM2 I was selecting the VCM2 option, not 'all other'.
It has connected now and I have managed to erase the 4 keys that were in there and re-program the one I had and the new spare.
So that's today's aim achieved. Thanks very much for the help.
Got the information from the PCM and it says the "cal" is 9C11-12K532-JC so not at all what it said on the label.
Found half a dozen DTCs so I'll spend some time investigating those before clearing them and seeing if they come back I guess.
Thanks again.
mike10
Postby Airthies » Tue Apr 25, 2017 6:37 pm
Bollocky scrote itch! IDS doesn't want to find the asbuilt file.
Bloody pooters
Bloody vans
Bloody CC......
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Apr 25, 2017 6:39 pm
Airthies wrote:Bollocky scrote itch! IDS doesn't want to find the asbuilt file.
Bloody pooters
Bloody vans
Bloody CC......
Do it manually mate :D
Ids map here
loot
Postby Airthies » Tue Apr 25, 2017 6:42 pm
Bloody pooters
Bloody vans
Bloody CC......
I'm trying to!
It's all where it's "supposed" to be!
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Tue Apr 25, 2017 7:17 pm
Loot dear sir. (As your the most likely guru but im not fussy)
What am I missing it's been ages since doing this
Downloaded asbuilt
Saved it in C:prog... fls (x86)/ Ford..M..C.../cal... files
But still no go.
BCM's been "installed" via ids.
Can suck out old config from bcm but not reformat with asbuilt
Grrr
Any thoughts?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Apr 25, 2017 8:54 pm
Just save the asbuilt to the desktop, turn off internet and then in config restore asbuilt and then locate the file you put on the desktop abcxyz.ab and it'll restore factory settings, will also reset config preferences tho.
Ids map here
loot
Postby Airthies » Tue Apr 25, 2017 8:56 pm
loot wrote:Just save the asbuilt to the desktop, turn off internet and then in config restore asbuilt and then locate the file you put on the desktop abcxyz.ab and it'll restore factory settings, will also reset config preferences tho.
Yea thought I remembered locating file before but can't get to that point again I'll go try again after some food and a ginger beer.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Apr 25, 2017 9:13 pm
Sounds good, although can you refer to it as non specific coloured beer pls. :lol:
Ids map here
loot
Postby Airthies » Tue Apr 25, 2017 9:23 pm
It was ginger! Crabbies said so!!!!
V86+patch
V86.04
X-Prog
C81
Airthies
