loot wrote:Vcm2 ids is a clone of what the manufacturers machine does and so in principle, if the manufacturers ids will do what you ask, and it is a function of the van to perform these tests then it should work, that said, we don't have an exhaustive list of what it won't do, a couple of ppl have had problem changing the mk6 axle for example, but we don't know if it was the clone or whether it can be done, hopefully someone will try it and then go to Ford and see if they succeed (but don't count on it just yet)
I wouldn't be without it for my mk7, mk6 I'm not so sure but yes you will be happy with it.
Aftermarket systems i think are made to read the pids and then the software interprets it, ids uses the actual ford software and the hardware is built to perform the function the same way.
The longevity of the hardware remains to be seen tho:-(
My vcm1 lasted a year and broke, my first vcm2 still works but has been playing up
I have a spare tho
Dear helpful loot, Heeeeeeeeeeeeeeeeeeelp please!
I am stuck! This follows my other thread about esp and abs MOT failure! Todate, just to refresh memory, I have changed 4 speed sensors, abs module from a 2014 mk7 (mine is 2007), returned speed cluster back to its original form and whilst at it changed the down- to- metal- rear pads that wasn't spotted by the MOT man! Refreshed the brake fluid, bleed it 2- man-old -fashion way. Brakes are good. Now need to get rid of the esp, abs and brake warning lights. In anticipation, I had already toyed with Delphi- good but not complete, and a vcm2 ids 101.03. Anyhow, after many packs of cigars and bottles of wine and stress- overeating days and nights, following this thread, going back to ids86 and flashing vcm2, managed to run some test. All seem to be ok, but ofcourse, less the ABS, ESP. It seems ids functions to test abs modules are available. But I presume abs needs to be programmed in- ids tells me "programming Modules" function is not available. Is it my ids or vcm2, or is some bits of software I am missing? Do I need some other hardware to program abs?
The fault codes are 4:
cmdtcs and snap date : U2101 68-2B C0063 08-2B C0063 4A-2B C1A93 14-2B all ABS and YAW sensor related, possibly due to change of abs module, etc. It is interesting to note that at somepoint, this van has had a rear right end damage- so I am assuming YAW was knocked sick, and to cure the warning lights the owner went through the trouble of modifying the cluster to hide the fault?? This is just a guess!
ABS/ESP test/ calibration- ABS- Routine- 3011; it came up with Longitudinal Acceleration Sensor fault! What is this??????
These faults could be meaningless unless the new abs module is programmed in- is this right?
Is there light at the end of tunnel?
Thanks for your help-
