scottie wrote:takworldwide wrote:cheers scottie, do you have a link from where you bought yours from?
not really,it was on ebay but ant remember the sellers name,it was in the UK though
A lot of them say there in UK but ship from China
grogan197 wrote:I'm trying to get the original calibration for my ECU but IDS won't accept my PCM Part Number of 4C11-12K532-AG. Keeps telling me it's incorrect.
Is there anyway to get it to recognise it? Does the IDS version matter (using v86)?
v8dave wrote:It may be you're pcm has been updated to a newer calibration than AG.
Assuming ids stores info on your mk6 tdci in the same way as it does for my mk7....
Set ids to log everything in a session then read the log file to see which calibration it has found in the pcm.
It will be near the top of the file, you should find (VIN): ######nnnnnnn, then Stratergy: 4C11-, then Filename: 4C11-12K532-AG
A few lines later you'll find (PCM) Part Number = 4C11AG, and (PCM)_FILENAME = 4C11-12K532-AG
If they don't all match then ids is not talking to your van properly.
grogan197 wrote:Thanks Dave. My problem is the ECU isn't the original one so IDS is reading it right but I want to reflash it to the original calibration.
v8dave wrote:grogan197 wrote:The biggest problem might be getting a copy of your calibration if you don't have it.
Users browsing this forum: Bing [Bot], traveler
