MK7 Map Sensor!
Re: MK7 Map Sensor!
Postby Gavin » Sun Jan 29, 2012 10:21 pm
if the map sensor gets this dirty what does the inside of the intercooler get like? :shock:
Gavin
Re: MK7 Map Sensor!
Postby Kidman » Sun Jan 29, 2012 10:53 pm
Really should check mine, its done 60k.. Bet the EGR isnt too pretty either!
2018 Transit Connect 140PS Tuned by STealthwerx TRS
http://www.facebook.com/kidmanspaint
Kidman
Re: MK7 Map Sensor!
Postby fedup2 » Sun Jan 29, 2012 11:48 pm
Kidman wrote:Really should check mine, its done 60k.. Bet the EGR isnt too pretty either!
If its like the rest of us it will be brand new :lol:
Launch x431 owner ;)
fedup2
Re: MK7 Map Sensor!
Postby pusd » Mon Jan 30, 2012 12:23 am
Gavin wrote:if the map sensor gets this dirty what does the inside of the intercooler get like? :shock:
It'll be fine as the egr enters the intake air after the intercooler, infact just before the MAP sensor!
Phil
pusd
Re: MK7 Map Sensor!
Postby Kidman » Mon Jan 30, 2012 2:07 pm
Took mine out earlier, completely blocked..
Kidman
Re: MK7 Map Sensor!
Postby Kidman » Mon Jan 30, 2012 3:14 pm
Before - Image
After -Image
Visible smoke has not improved much, its not bad anyway, just a puff as it pulls hard on boost (its been remapped 800 miles ago),to be honest its not been driven hard in its lifetime, so this will improve over time, the idle is rock steady at 800rpm now, before it could be a bit inconsistent, its also crisper throughout the rev range.
Kidman
Re: MK7 Map Sensor!
Postby subarumark » Mon Jan 30, 2012 7:45 pm
is itjust a case of unplugging it removing 1 screw and pulling it out to get it out to clean it what did u use to clean the sensor
subarumark
Re: MK7 Map Sensor!
Postby blue estate » Mon Jan 30, 2012 7:46 pm
subarumark wrote:is itjust a case of unplugging it removing 1 screw and pulling it out to get it out to clean it what did u use to clean the sensor
Yes it's that easy :wink: petrol is best
blue estate
Re: MK7 Map Sensor!
Postby Kidman » Mon Jan 30, 2012 8:06 pm
I used carburretor cleaner although you could use alcohol (not vodka) or contact cleaner, removed the excess first with a tooth pick and then blasted it. Idles amazing now, for a ten minute job its worth doing at every oil service. FWIW the MAF sensor was very clean,debating cleaning the EGR next.
Kidman
Re: MK7 Map Sensor!
Postby herman0786 » Tue Jan 31, 2012 6:51 pm
what does the map sensor actually do?
herman0786
Re: MK7 Map Sensor!
Postby Mike » Tue Jan 31, 2012 7:12 pm
herman0786 wrote:what does the map sensor actually do?
Measures pressure.
Mike
Wind up merchant!
Re: MK7 Map Sensor!
Postby subarumark » Sat Feb 18, 2012 2:44 pm
cleaned mine today it was very dirty seems to of made it more responsive unless iam just imagineing it does cleaning it make it go better
subarumark
