Rear brake disc change questions
Re: Rear brake disc change questions
Postby reevco62 » Tue May 16, 2017 10:31 pm
blue estate wrote:You're right n/s is l/h thread o/s is r/h thread
One has blue ring one has yellow ring
Thought so, thanks.
It takes thousands of nuts to hold a Transit together but only one nut behind the wheel to distribute them all over the road...
reevco62
Postby reevco62 » Wed May 17, 2017 8:06 pm
Made up tool today to separate disc from hub using an old front disc from my Cortina it should do the job just fine
https://www.youtube.com/watch?v=V7fpafGcULk
People have said you can damage the wheel using it like in the video above so made this just thinking the bolts will be to long
My home made tool
Tool made by Laser
Laser link
Amazon link
eBay link
Hoping it will stay dry tomorrow
reevco62
Postby reevco62 » Thu May 18, 2017 8:16 pm
Well got the rear discs done today, quite easy job really just time consuming first side took me around 4hrs to do the other side took about hour and a half hardest part was getting one of the pads in it just didn't want to go in.... my drilled out disc worked well and popped the old disc off in seconds no trouble.
Next on to the front ones
reevco62
Postby reevco62 » Sat May 20, 2017 8:48 pm
Made a short 5min video of how I did the job
https://www.youtube.com/watch?v=gGCBpCnMOlY&t=90s
reevco62
Postby Punto443 » Sat May 20, 2017 9:59 pm
Looks very professional!
I just smashed a cold chisel inbetweem the back of the stars and disk on mine :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby reevco62 » Sat May 20, 2017 10:57 pm
Did the fronts today, wishbones too while it was all stripped down
Still to do the video for the front will post once it's up on YouTube but found the front to be far more involved and a lot more work
Thanks to all here who helped with any questions I asked about this job.
reevco62
Postby reevco62 » Tue May 23, 2017 2:34 pm
Done the video for the front discs
https://www.youtube.com/watch?v=kqR9q2JAlnI
reevco62
Postby syberchef » Wed Jun 19, 2019 6:31 pm
What size are the disc bolts guys?
Sent from my SM-N950F using Tapatalk
syberchef
