How to add factory cruise on a mk7 transit no pics
Re: How to add factory cruise on a mk7 transit+pics
Postby loot » Thu Feb 13, 2014 11:13 pm
I'd agree there, as most transit owners use them for working, it is understandable that functional things which make life easier, are much more important than pretty shiny things.
:wink:
Ids map here
loot
Postby soprano1982 » Sun Feb 16, 2014 10:08 pm
The wiring is baffling me :roll:
I've already got the c series bcm in my van as standard from factory with the trip Computer multi function stalk - I've got a cmax steering wheel now- I took the airbag out this morn hoping there would be a plug but there isn't just a blank hole with no pins - so my question is where would I find the ford plug - to be able to
Make my own ? I'm going to get martyn to enable it all
soprano1982
Postby loot » Sun Feb 16, 2014 10:13 pm
In the cmax steering wheel, you should have the buttons and for the buttons they will wire to the main connector, you'll have the srs at the left then in the middle you'll have 2 wires for the cruise then 2 wires for the horn.
The connector on the outside of the squib under the steering wheel Is where the2 wires need connecting they then get fed though to the bcm where you'll connect then to where i have already said,
If you don't have wires there then you need to make them up.
:wink:
Ids map here
loot
Postby soprano1982 » Mon Feb 17, 2014 12:23 am
Does this look right then ? Wiring isn't my strong point :lol
soprano1982
Postby soprano1982 » Mon Feb 17, 2014 12:26 am
soprano1982
Postby soprano1982 » Mon Feb 17, 2014 12:30 am
soprano1982
Postby loot » Mon Feb 17, 2014 1:05 am
Yes your steering wheel is squared away so fit it and put it back together.
The other side of the squib needs the 2 wires present, they are located at pin 4 and 5.
Ids map here
loot
Postby Stacker » Mon Feb 17, 2014 10:25 am
I have the same cups as you but in brown and green!
2006 Transit Jumbo 115PS - Had it stolen, written off and now brought back - SOLD!
2010 Transit Jumbo 140PS Sea Grey - Still going on 227k! - Jan '19
2005 Transit LWB Hi Top 135PS -Sold, thank god
Stacker
Postby Rumble bee » Tue Feb 18, 2014 7:31 pm
Just doing my cruise wheel, does anybody know where these extra wires go?
Two Brown and a black, come out of the extra connect on the bottom of the squib.
Cheers
Chris
Rumble bee
Postby loot » Tue Feb 18, 2014 9:38 pm
Have you got wires going to 2 plugs on your squib?
Ids map here
loot
Postby loot » Tue Feb 18, 2014 9:59 pm
Just re read, you don't need the bottom connections, i do tho and have been looking for ages lol, tbh i think they are for something we don't know, on a focus?.
For what you want you need the top connector with 4 wires plus srs connector, bottom just unplug.
Ps can i have the part number for your squib if possible please.
:o
Ids map here
loot
Postby soprano1982 » Tue Feb 18, 2014 10:06 pm
Chris - can you take pics once you sort it might help me - I'm going to open it up again Sunday :D
soprano1982
Postby loot » Tue Feb 18, 2014 10:11 pm
He's probably done it now :(
Soprano it is very simple, Chris has a 1 off squib.
When you take the airbag of yours you'll see the black and brown wires, so remember where they go on the new 1 as they are for the horn the same as yours.
The new wheel connector with buttons is plug and play and so is the airbag connector.
:wink:
Ids map here
loot
Postby Rumble bee » Tue Feb 18, 2014 11:17 pm
loot34 wrote:Just re read, you don't need the bottom connections, i do tho and have been looking for ages lol, tbh i think they are for something we don't know, on a focus?.
:o
Lost me there mate, do you mean the three wires im holding aren't used?
Rumble bee
Postby mk7newbie » Tue Feb 18, 2014 11:19 pm
loot34 wrote:He's probably done it now :(
:wink:
Sorry to sound daft loot but to re cap on the cruise control if I have the correct box ending in c and get the correct steering wheel is it just a case of connecting plugs that are already there???
mk7newbie
