by bazw » Thu Jun 18, 2015 11:55 am
If battery is dead as a dodo in a week the diode pack in the Alternator may have gone, this would allow a flow of current all the time it is turned off.
do you have a multi meter? if so check alt output as it may be reading high with a fault in it, and when disconnected and read across main connection you will see a DC amperage reading when all is switched off.
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
