DTC P121c injector leaking after replacing PRV and SCV
Re: DTC P121c injector leaking after replacing PRV and SCV
Postby loot » Tue Apr 28, 2015 8:02 am
Are all the bad ones identical do you know?
I'll post a picture of a brand new Ford 1i have.
We could do with a prv/scv thread i think :-)
But i think with the amount of bad ones around I'll be paying a bit extra at Ford :-(
Ids map here
loot
Postby tibsy » Tue Apr 28, 2015 8:51 am
loot wrote:Are all the bad ones identical do you know?
several on ebay but which if any are "good ones"?
what price is "genuine" one from dealers or other source?
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Postby loot » Tue Apr 28, 2015 9:18 am
Well here's the genuine Ford 1:-)ImageImage
Last 1 i did came with what liked like am ally washer which was quite thick and got quite damaged when used, perhaps that ties in with what you said about the fake ones martyn?
You can see why they are worth cloning since Ford want a fair price for them :-(
Ids map here
loot
Postby Vikane » Tue Apr 28, 2015 5:55 pm
Interesting, I will email and confront them about this.
Only had time to replace the prv today, no IDS learn process.
But with a genuine Ford prv, the code was gone, and the car driveable :)
Will try the IDS tomorrow, if everything goes as planned.
'08 Transit T350 Jumbo
Vikane
Postby bazw » Fri May 01, 2015 3:12 pm
what does the Gen ford one retail for? any one know?
and any update on the cloned ones as to which supplier has good copies or bad copies?
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby loot » Fri May 01, 2015 6:36 pm
I paid 160 over a year ago from Ford for both valves but have read they can sell for 200+ now :-(
If you can get a genuine denso 1 from them then I'm sure that would cost less but i don't know if they sell direct?
No idea on aftermarket sellers :-(
Ids map here
loot
Postby Transitpartsuk » Tue May 05, 2015 3:39 pm
loot wrote:There is a chance the valves are OK but you need to diagnose the fault tbh, it could be something simple but until you check the above then your stuck :-(
If the valves are faulty then transitparts.co.uk will probably swap them for good ones. :wink:
Not purchased from us, transitparts.co.uk are a different company to us
Transitpartsuk
Registered Trader
Registered Trader
Postby loot » Tue May 05, 2015 3:46 pm
Thanks for pointing that out, think i was being lazy rather than typing the full name :-(
My point tho was that either company would replace them.
Buy i see your point now :oops:
I will edit it correctly :wink:
I still don't know who is who tho lol
Ids map here
loot
Postby Transitpartsuk » Tue May 05, 2015 10:23 pm
No worries :) would swap them over no probs if it was us.
tpuk.net / transitpartsuk is us!
Transitpartsuk
Registered Trader
Registered Trader
Postby griffin41 » Sat May 16, 2015 9:45 am
loot wrote:Thanks for pointing that out, think i was being lazy rather than typing the full name :-(
just a word about transitpartsuk - i was sent wrong part just the other day and after a call to them they sorted me out without any problems at all - that was an ebay sale - not prv or svc related but shows the company is one you can trust - still i now know the difference between a mk6 and mk7 hub knuckle now - 5 stars on the way :lol:
that is not my belly - i just need to make that clear and if you find a cure let everyone know it
griffin41
Postby griffin41 » Sat May 16, 2015 10:49 am
iv just this minuet got one from ford prv £71 - and i got quote for scv £140
ford ones are lazer printed on the side not stamped like aftermarket items
griffin41
Postby bellywipe » Sat May 16, 2015 6:54 pm
I guy’s I bought a timing chain kit for a mk6 transit from transitparts.co.uk ( e-bay ) £125.00 it was so fake lasted less then fore week’s before it jumped and smashed my cylinder head to bit’s cost me over a £1,000 to repair it, bought the next one from a good retailer cost around £350.00 side by side you can tell by a mile, van still good and that was just over two years a go, transitparts.co.uk ( e-bay ) are a joke
bellywipe
Postby Vikane » Sat May 30, 2015 1:01 pm
Also tried module programming in the menu, but message says: Selection is not available.
Any idea what it means ?
Vikane
Postby loot » Sat May 30, 2015 1:37 pm
Vikane wrote:Also tried module programming in the menu, but message says: Selection is not available.
In my signature there's a link for ids, go to it and download xprog, extract it to desktop and then run it and it will enable your module programming 8)
Ids map here
loot
Postby Vikane » Sun May 31, 2015 9:35 am
I am having problems with posting here at the moment, some text was lost in my last one.
I try again:
Finally, after 14 days of struggeling with IDS installation, I managed to get it to work, connected to the Van, and all learn processes went through.
The Van is better, but still experincing some misfire, I suspect a injector, but did the injector test, and couldn't notice a big difference.
Vikane
Users browsing this forum: misterdog
