Mk7 denso injectors
Re: Mk7 denso injectors
Postby loot » Thu Aug 20, 2015 9:03 pm
I'm posting a couple of pages Dave because they contain the info i have always asked about :wink:
Note that the info may be biased.
Summary extract.
There is no concrete set of instructions or test data to produce a perfectly repaired product. there is however, an opening to offer something other than a brand new injector in a box.
The repair concept here is to offer the user the ability to learn as you go based on info obtained from new units.
Ids map here
loot
Postby paul2012 » Thu Aug 20, 2015 9:30 pm
MK7 2.2 injectors
110ps 6C1Q-9K546-AC
115ps, 130ps & 140ps 6C1Q-9K546-BC
155ps from 2011-2013 BK2Q-9K546-AG
Mk7 2.4 injectors
100ps & 115ps 6C1Q-9K546-AC
120ps 1C1Q-9K546-BA
135/140ps & 140ps HPCR 6C1Q-9K546-BC
135/140ps with DPF 9C1Q-9K546-BA
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby loot » Thu Aug 20, 2015 9:39 pm
Hi Paul I'll be honest the numbers in the box i posted make more sense tbh.
Mine are bb and you haven't listed them.
Can you confirm?
All modules seem to be variants abc with revisions abc so it would make sense that aa ab ac would be low flow and ba bb bc high flow.
Confused. Com Lol
I understand your later and dpf injectors being revised completely, but isn't the 2.2 155 the same engine? Or is it a super high flow injector? 8)
Ids map here
loot
Postby v8dave » Thu Aug 20, 2015 9:54 pm
Interesting, does the 2011-13 155ps really use the low flow injectors ?
According to denso the injector does the fuel delivery in 5 or 6 pulses per firing. A single large pulse would cause knock so they spread the fuel delivery to keep the temperature down and improve emmissions. Trouble is I can't find the document I downloaded some time ago, I'll look later - time to go out and see friends rather than spend all night in front of a computer.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby paul2012 » Thu Aug 20, 2015 10:05 pm
loot wrote:Hi Paul I'll be honest the numbers in the box i posted make more sense tbh.
Can you confirm?
Confused. Com Lol
They are the current part no's listed with Ford & no OSI (Revised part no's are listed wit OSI)
& yes there is several different engines listed depending on engine power & emissions standards :wink:
paul2012
Postby paul2012 » Thu Aug 20, 2015 10:08 pm
v8dave wrote:Interesting, does the 2011-13 155ps really use the low flow injectors ?
155ps from 2011-2013 BK2Q-9K546-AG are Siemens injectors not Denso :idea:
paul2012
Postby dieselhead123 » Thu Aug 20, 2015 10:12 pm
You will never know unless you compare Nozzle data :idea:
There must be chaps on here that know the Nozzle part numbers :?:
Postby dieselhead123 » Thu Aug 20, 2015 10:18 pm
paul2012 wrote:155ps from 2011-2013 BK2Q-9K546-AG are Siemens injectors not Denso :idea:
Is it the only engine that uses the Siemens units Paul?
We have a 'dead' engine with these in, (no idea what vehicle it came from though), I could pull one and get the Nozzle specs for comparison :idea:
Postby paul2012 » Thu Aug 20, 2015 10:31 pm
Those injectors are fitted to Euro 5 2.2 FWD engines. (Which is a different engine to the earlier Euro 4's)
They are also fitted to Transit Custom :wink:
paul2012
Postby v8dave » Thu Aug 20, 2015 11:57 pm
Ahh
The difference between part numbers and location codes :lol:
v8dave
Postby v8dave » Fri Aug 21, 2015 12:01 am
loot wrote:Aw your no fun are you Dave :? What's it like having friends then? :P
"Friends" was possibly the wrong choice of word.....
The people I interact with down the pub do not normally pull up a thread history to prove I've made a mistake :oops: :lol: :lol:
v8dave
Postby paul2012 » Fri Aug 21, 2015 3:18 am
Forgot to mention mk7 2.2 85ps injectors are also 6C1Q-9K546-AC :wink:
paul2012
Postby loot » Fri Aug 21, 2015 8:25 am
Paul are bb the right ones for 2.4 140? :-)
Ids map here
loot
Postby loot » Fri Aug 21, 2015 11:13 am
14mm deep socket and a 1m pipe wrench undid it without any damage.
My nozzle part numbers are.
Ej D DLLA153P885 were written on the side.
The diesel around the nozzle was black and oily.
Ids map here
loot
Postby v8dave » Fri Aug 21, 2015 1:00 pm
That looks like a new injector !
How about this....
Will see if I can open one later.
Trying to paint the side door sill.
v8dave
