Connect your MP3 Player to your MK7 Transit
Postby Spooky_b329 » Thu Aug 09, 2007 10:26 pm
Lead is one I've had lying around, thought it was to blame so spent a tenner on a new one. Doesn't solve the problem so thats going back for a refund!
Player is a Soniqcast Aerio, will double check the output with headphones but I've never noticed a problem. Also it has two jack sockets so you can listen with a friend, but swapping to the other doesn't fix it.
http://images.google.co.uk/imgres?imgur ... l%26sa%3DG
Spooky_b329
Postby sc_BK » Thu Aug 09, 2007 10:33 pm
As I say try using the same player and same lead as input for something else like PC/hi fi etc
Also try using the same lead going from another device like a personal CD player/phone/different MP3 player, into your headunit
sc_BK
Postby Nighthawk » Thu Aug 09, 2007 11:02 pm
You've not pressed the front of the socket all the way into place
Give it a good poke and you'll here it click, sound quality will improve ;)
It is a 3.5 standard stereo connection, I was probably a bit p1ssed and missed the .5 off when I posted originaly
:D
Transit.........Job done
Nighthawk
Postby Spooky_b329 » Fri Aug 10, 2007 4:35 pm
Thanks!
Gave it a good shove and the faceplate clicked home properly and its all working fine :)
Spooky_b329
Postby Nighthawk » Sat Aug 11, 2007 8:49 pm
what can I say................. :lol:
Nighthawk
