Fitting side marker lights
Postby MrMPuk » Tue Aug 14, 2007 1:24 pm
Black to earth and Red to the feed.
Postby Lee J » Tue Aug 14, 2007 3:54 pm
ok, so if im running 3 markers on each side would i have to earth them all individually ? and what about the 3 reds?
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby MrMPuk » Tue Aug 14, 2007 3:57 pm
Earth the lights straight to the fixing bolts holding them in. The reds need that feed from the relay you are putting in.
Postby DOL » Tue Aug 14, 2007 5:35 pm
i agree with the relay approach even tho im rinning 8x extra orange side markers,5x extra rear markers & 4x extra front markers without a relay :oops: with no problems for last year or so :D only things ive put relays on are air horn and 1 to the 4 roof spots & 1 to the pair of bottom spots & 1 to the spots on front a bar :D but then again im not a qualifeid auto electrician :lol:
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Postby thunderider » Tue Aug 14, 2007 8:43 pm
use red for power black for earth.
I am the god of hell fire.....
thunderider
Postby Spooky_b329 » Wed Aug 15, 2007 2:21 pm
I was wondering, would it be possible to fit side marker lights so that they operate as running lights, then when turning on the indicators, get them to dim between the indicators flashing?
i.e. when you activate the indicators, they will dim to say 50% during the time the indicator bulbs are off, so in effect flash in time. When the indicator bulbs are on, the side markers would return to 100%, then 50%, 100% and so on.
Must be possible, but how much of a faff would it be?
Spooky_b329
Postby Lee J » Wed Aug 15, 2007 3:29 pm
this is what i need to do then...
Lee J
Postby MrMPuk » Wed Aug 15, 2007 3:38 pm
Lee J wrote:this is what i need to do then...
It's a touch small. Kinda looks like it though.
Postby viper » Wed Aug 15, 2007 4:30 pm
Its easy, a resistor is need to dim your side lights by what ever percentage you require but a diode is also required to prevent feed going to your tail lights, front park/side lights and top markers if fitted.
Feed from indicator is then attached to your side markers direct but a diode is inline to prevent return power when your side lights are on.
If using LED marker lights a relay is not that important as draw is minimal, per side you might be pulling an extra 500 milli amps to 1 amp, if fuse doesnt blow then you can rest assured the wiring is more than capable of suppling good power to your LEDs, if lighting is marginally dimmed when connected it would be an ideal time to upgrade the earth on back lights as connector that is used is pathtic, done mine today as lights were pulsating indicating poor earth
Custom interior, MK6 MWB RWD 90PS 2000)...220 000miles, parked up for 3 years rust free
viper
