Ah yes silly me oops forgot it showed on the tramps pageloot wrote:You don't need etis log in, just go to etis put the reg in then scroll down to the vin and copy it then come here and paste it in and that's it. Still more than we want to do but is easy enough
Dodge20 wrote:Doesn't work with my van. It tells me it's a custom then requires me to input all details such as build date, paint colour, interior trim etc etc.
loot wrote:Type the vin in and then it shows the model to select which when you click on it out then opens up all the build info.
loot wrote:Additional options:
Complete Vehicle
Less MPH Engine Governor
Less Rear Seat Armrest Packs
With Tunnel Mounted Parking Brake
With Single Rear Wheels
Less Float Mounting
Less Temp Control Passengers Seat
Less Side/Rr Door Security Lockset
Less Rear Compartment Trim Panel
Less Seat/Airbag Pack
Less Smokers Package
Less Trim Pack
Less Passenger Seat Armrests
Less Engine RPM Control
Less Heated Rear Window
Less Auxiliary Fuse Panel
Less SVO Application/Label
Less Rear Stabilizer Bar
Less Dual Rear Wheel Pack
Less Diesel Fuel Cooler
Less Passenger Seat Valance
Less Battery Cut Off Relay
Less A/C Unit - Roof Mounted
Less Temp Control Driver Seat
With Black Air Vent Knob
Less Roof Flasher Wiring
Less 2nd Row RH Side Window
With Visibility Pack
With Rear Mudflaps
With Heated Windscreen
With Column Stalk Radio Controls
With High Mounted Stop Lamp
With Spare Tyre Security Package
Less Auxiliary Heater
With Front Towing Hook
Marketing Flex Prep Pack 1
With Instrument Panel Dimmer Switch
Less Passenger Air Bag
With Load Space Tie Down Loop
Less Optional Equipment Pack
Less Rear Window Protector
With Trip Computer
Less Rear Window Wiper/Washer
With Power Equipment Group
With Drivers Seat Fixed Armrest
Rain Sensor - Fr Windscreen Wiper
With Front Roof Grab Handle
Less Rear Seat Belts
With Manual Headlamp Levelling
With Dual Side Load Doors
With Power Front Windows
European Environmental Label
Blue Tooth Interface Connect
With MPH/KMH Speedometer
With Automatic Headlamp On/Off
Fuel Water Separator Less Sensor
Extra Heavy Duty Battery
With Telephone Prep Pack - Design B
With Front Fog Lamps
Cold Start Up To -20%c
Marketing Level 3
Seat Pack 22
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
With Recirculating Heater
With Rear Blanking Panel
With Door Dead Locks
Less Adjustable Passenger Seat
Remote Control Door Entry - 2 Fob
Voice Activated Module - British
With Full Wheel Cover
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
With Full Partition - Steel
With Driver 6 Way Mnl.Seat Adjuster
Less Rear View Mirror
Ice Feature Pack 3
Large Head/Short Arm Mirror
Less 2nd Row Rear Seat
With All Light Tinted Glass
With Sngle.L/B Dvr/Dual L/B Pass.St
RHD FWD
Front Bumper Body Coloured Plastic
Otosan (Turkey) Plant Build
LX Sales Badge
Stage IV Emissions
4.54
Lichen
Regular Cargo Van
(+)"GB"
350M Series
Transit 2006-
2.2L Duratorq-TDCi (130PS) - Puma
Moondust Silver (Metallic)
Tomy (G-C)
Auld Bettsie is asbos little sisterloot wrote:Certainly does
loot wrote:8)
I've read that some campers have the handbrake on the right side of the driver seat to allow swivel, but that may be an addition from a coach builders, you do see some options in config that do seem standard and obvious though
