I was trying to find the thread where I changed mine but couldn't find it
Here's what I would do,
Remove the glove box door and rear part of the glove box (think I had to shove it to the side as it wouldn't come out fully).
Cut the mat to reveal the 3 x 10mm nuts and loosen them.
Loosen the 36mm hub nut (on the drive shaft) remove the road wheel, track rod end, drop link, pinch bolt and the little bracket holding the brake Flexi.
Remove the 36mm hub nut so you can move the knuckle in and out.
Knock the knuckle down with a lump hammer until you can get the bottom of the shock strut out (you may need to pull the top of the knuckle towards you)
Once the bottom is free remove the 3 top nuts and the shock will drop free.
