BCM wiring diagram pin data
Re: BCM wiring diagram pin data
Postby knobby1 » Fri Mar 20, 2026 12:58 am
IanLa wrote:I’ve got a slightly different issue but you all seem to know a lot about wiring :D
Does anyone have a wiring diagram for Custom 2019 I’ve got an issue with when I lock the van with FOB or key the doors all lock but the horn sounds as if there’s a door unlocked, tried replacing sliding door pins and rear door lock but no joy…Battery voltage is fine. Any ideas ..??
This is the Mk6 & Mk7 group 2000 >2014...why don't you try the late model Custom group..??
viewforum.php?f=65
Lord Knobrot (Smithy)
