problem starting when engine is warm/hot
Re: problem starting when engine is warm/hot
Postby Candoo » Sun Dec 24, 2023 2:24 pm
Hi, my transit has similar issues. Did this get solved? Cheers Craig
Candoo
Postby ant_harvey » Mon Jan 01, 2024 3:21 pm
knobby1 wrote:
ant_harvey wrote:I have run tests with my ELM 327 and no codes shown for any modules.
Using Forscan via the ELM-327..?? Or another program..??
Yes using Forscan with the ELM-327
ant_harvey
Postby ant_harvey » Wed Jan 24, 2024 8:07 pm
Quick little update and a follow up question - so I have now replaced both batteries (they were done) and today fitted a new starter motor (also goosed). The youtube vids I used didnt show this magic little black plastic housing around the terminals - that was a pain in the b-hind. Im all up and running again but there is a loose wire, looks like a sensor. It might have been hanging down before or I might have dislodged it in my struggle to get the terminals disconnected. Can anyone identify it and politely tell me where to stick it?
ant_harvey
Postby ant_harvey » Wed Jan 24, 2024 11:11 pm
A quick follow up - in the picture have I wired this correctly? I have the live (thick red) cable going to the 12mm, earth goes to the bolt securing starter to the engine and two wires to the 10mm switch pole.
I only ask as on my test drive the solonoid didnt disengage and Ive already burned out my my starter - well thats my verdict. Engine Malfunction showing on dash / engine cut out / nasty plastic burning smell / very hot body (no, on the starter not me!). Thanks and please explain why Im a dumbass or could it be a duff starter?
ant_harvey
Postby ant_harvey » Wed Mar 27, 2024 6:34 pm
Solution: Its all fixed and running normally; turns out it was fairly simple - a new starter (£50 from ebay) and replacement battery (£100). Its been running perfectly now for a couple of months so safe to say its sorted. Thanks for advice and support.
ant_harvey
Postby ant_harvey » Sun Apr 13, 2025 4:54 pm
It might have been a false economy buying a £50 starter in ebay as its happening again. I will buy one from my local motor factors this time!
ant_harvey
Postby vansit1 » Sat May 17, 2025 8:18 am
isnt that like a wire for the starter or just check where the other loom goes to, and which engine/year is it
vansit1
