Mk 7 transit engine wiring harness. Help needed
Re: Mk 7 transit engine wiring harness. Help needed
Postby Airthies » Thu May 29, 2025 10:43 pm
knobby1 wrote:
l200lc2 wrote:forscan says is definitely a 2.4 so i must have got that bit wrong but ebay lists loads of different variants for rwd engines.
how can i confirm i have the correct wiring harness?
cheers lee
Mk7 Euro-4 2.2 and 2.4 engines are vastly different. Mk7 Euro-4 2.4 only came in three variants, 100, 115, & 140. The 100 and 115 engines are near identical, the only difference is the 115 came from the factory with a 6 speed gearbox and the PCM mapping is different. The 140 is quite different, different injectors, 6 speed, two oil filters and electronic VNT turbo. You need to find out which you have as the engine harness is quite different. Can you take a photo of the engine for us..??
Just as a curiosity "point of note". The 115 harness often has the VNT plug (clipped to the power steering bracket) but running the std waste gate turbo.
I've fitted a 100ps 5sp harness onto a 115ps engine without issues.
(Might have needed to extend the reverse switch wiring but may be wrong. It was a looooong time ago.... ) but nothing major.
All plug n play on a poverty spec van.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
