P1796:00-6C-IPC Kick Down Switch Circuit Malfunction
Re: P1796:00-6C-IPC Kick Down Switch Circuit Malfunction
Postby DanMK7uk » Thu May 15, 2025 12:53 pm
Tried again, injector pilot learn then passed
Iv codes saying pump learn failed and injector pilot learn failed
Im aware that it does throw a code during the learn process, which iv cleared but they keep returning.
Also had an orange cog light on during learns cant say i recall that before….
There may well be something still wrong … il await what you guys think
Just to add open prv counts also were reset..
Cheers
DanMK7uk
Postby DanMK7uk » Thu May 15, 2025 2:36 pm
P268b
P167b
Cog light gone (was during the learn it was on)
Van still hunts … its better but still jumping pressure intermittently…
New genuine valve on…
Swapped fuel filters from other van … same
Forscan said 100 completed on both learns (eventually on injector learn) after a few attempts.
But yet still throws codes up when cleared why would this be ?
Some air is evident in clear hose… ingress maybe or where i had scv out ?
Will maybe try another run of learns
My only other thought process is it’s scraping by the learns, (perhaps why it failed the first couple times) and when running the injectors are out ? Leak down maybe my next option il check cyclinder contribution factors when back to van later.
DanMK7uk
Postby DanMK7uk » Thu May 15, 2025 3:44 pm
Cylinder balances
1 0.7 mg
2 0.2 mg
3 1.3 mg
4 0.4 mg
DanMK7uk
Postby DanMK7uk » Thu May 15, 2025 6:21 pm
So forscan refused to clear the two P CODES.
P268b and P167b.. seemingly related to failing of learns
Popped on my topdon scanner and now both have gone and not come back… suprised forscan didnt delete them i tried 10 times with it lol.
Anyway they have gone and not come back.
Im still showing a P1796:00 6C can bus off
and a C004A:13:28
To which neither pieces of equipment will get rid of.
Permanent faults. New this last couple days.
Van at this moment is starting and idling nicely.. stable bar pressures.
Perhaps all is okay or its playing a game of cat and mouse
DanMK7uk
Postby andz327 » Fri May 16, 2025 12:56 am
knobby1 wrote:
andz327 wrote:Check the opaque fuel pipe that goes from filter to pump, since having this problem muself at one point I've seen a few with ssme problem, thetes a tunner hose that rubs against this plastic opaque pipe and actually erats a hole through and can be intermittent as the rubber hose sits on the hole and sort of seals it if the rubber hose not secured properly and the hole can be hard to find ImageImageImage
I believe he's working on a RWD....2.4 engine doesn't have the opaque line champion....I believe it's a FWD only thing.
Don't think so ma laird knobberoo your wrong but yer correct
andz327
Postby DanMK7uk » Fri May 16, 2025 1:08 am
Appreciate the heads up tho andz, a good thing to be aware of particularly with the coolant hose acting a temporary/ intermittent seal when in contact. Definitely something that could catch people out. Im sure that will help someone reading through these one day.
Ford ask silly money for them pipes.. i repaired one on my other van.
We will let knobby off lol
Van running well, i think it was a combination of matters.. scv poorly and air possibly see on start up tomorrow and check my filter levels..
Cheers
DanMK7uk
Postby andz327 » Fri May 16, 2025 1:12 am
DanMK7uk wrote:Appreciate the heads up tho andz, a good thing to be aware of particularly with the coolant hose acting a temporary/ intermittent seal when in contact. Definitely something that could catch people out. Im sure that will help someone reading through these one day.
Cheers
Would happen intermittent for about a week, 4 times i filled the filter before i noticed the actual problem, cheap on ebay for new yins
andz327
Postby andz327 » Fri May 16, 2025 2:16 am
https://ebay.us/m/Qg3tz7Image
andz327
Postby DanMK7uk » Fri May 16, 2025 12:24 pm
Update on the situation.
Done 50 miles today van running great.
No hunting and no power loss at 2k revs
The P CODES have all gone and not returned.
No air ingress overnight and deliberately parked it on a slope with engine up so im confident air ingress was not the reason, i believe the new scv and learns have done the van good.
Hopefully it will be ok.
Chees
DanMK7uk
Postby gt_addict » Fri May 16, 2025 2:22 pm
Glad to hear it. Thankfully a fairly easy fix.
gt_addict
Postby DanMK7uk » Fri May 16, 2025 4:23 pm
gt_addict wrote:Glad to hear it. Thankfully a fairly easy fix.
Hopefully it will remain so lol
Cheers
DanMK7uk
Postby vansit1 » Tue May 20, 2025 6:00 am
is that a faulty adapter then and what are the live numbers for a working engine now?
vansit1
Postby DanMK7uk » Tue May 20, 2025 9:53 am
scv
230 bar at idle plus minus 10%
Cheers
DanMK7uk
Postby vansit1 » Tue May 20, 2025 6:55 pm
i mean if it didnt erase the codes, plus what engine was it and what are the Maf, Map and Egr readings too at various rpm?
vansit1
Postby DanMK7uk » Tue May 20, 2025 7:17 pm
vansit1 wrote:i mean if it didnt erase the codes, plus what engine was it and what are the Maf, Map and Egr readings too at various rpm?
What is it you need to know ? What problems are you having…
DanMK7uk
